Thanks Thanks:  5
Likes Likes:  19
Results 1 to 26 of 26
Thread: Jespinosaesq's MKIV "Godzilla" Build Thread- Godzilla Engine Installed!!
    Mar 2023
    Miami, Fl
    I have been interested in building an MK IV roadster for years but never got around to it. A friend of mine knew that I always wanted to build a roadster and caught wind that someone local had a kit and was interested in selling. When I went to look at the MK IV Roadster kit, the kit was in its early stages of the build and the Seller had already purchased an engine and transmission. I had always wanted to build the MK IV with the Coyote, but the Seller had already purchased the 7.3L Godzilla engine. We went back and forth for a while, and it made sense for both parties to sell the kit with the engine and transmission together. At first, I was worried since there is a wealth of knowledge on the Coyote swap but not much info on the Godzilla swap, but I remembered that at one point the Coyote swap was not very common and it took a few years before it got to its current state. Additionally, there are quite a few experienced builders on this forum that could help with my multitude of questions.
    So, I am building my MK IV with a Godzilla and TKX and figured it would be a good idea to document the build on the forums. The car will be a cruiser/driver to be used on the weekends or during the week to go to work or take my kids for a joy ride. I want to build positive memories for my children during the build process and selfishly get them into cars at the same time while I get to enjoy my hobby. Below are a few basic details on the kit purchased.
    Purchased October 2023/ Kit produced 04/2022
    Mk IV complete Kit, Powdercoated Chassis, and body cutouts
    31 Spline IRS 8.375' Driveshaft
    Black Vinyl Seats
    Power Steering Components
    2015 IRS Parts Kit
    FFR GPS Gauge Set
    17x9/10.5 Halibrand Wheels and Nitto Tires
    Wind Wings
    Sun Visors
    Front and Rear Swaybar
    CF Dash w/ Glove Box (Purchased later)
    MK IV Logo Floormats
    Center Dash Support
    14" Leather Steering Wheel
    Trunk Gas Strut Kit
    12.88 Front Wilwood Brakes (Red)
    Hydraulic Clutch Master Cylinder Kit
    Brake Duct Wire Mesh
    Blank Dash
    Engine and Transmission:
    7.3 Godzilla Crate Motor 525hp package by Proformance Unlimited
    Zero Degree Timing Lock Out
    Custom Oil Pan (modified for needed clearance)
    Behive Performance Valve Springs
    ATI Super Damper Harmonic Balancer
    Holley Fuel Rail Kit
    Holley Terminator X-Max Computer
    Custom Wiring Harness for the Holley
    CVF Pulley Kit
    MSD 8.5MM Plug Wires
    Indy Power Products Billet Valve Covers
    Tremec TKX
    Flywheel/ Clutch/ Bellhousing
    Apex Solutions Hydraulic Clutch
    Additions:
    Russ Thompson Drop Trunk
    Ie427 steering wheel hub w/ quick disconnect hub (Future purchase when ready)
    Forte Godzilla Motor Mounts
    And honestly many, many more parts I have yet to think about.
  2. Thanks Hoity thanked for this post
    Mar 2023
    Miami, Fl
    Here are a few pics from when we went to go pick up the kit.
    I never realized how many boxes where in the kit till the day I went to pick them all up...
    The Godzilla Engine fit in the truck bed with a few other boxes
    A few forum members recommended a U-haul trailer and it worked perfectly
    We though we wouldn't fit all the boxes in one trip but we were able to. This is just some of the boxes but it made for a good picture.
  4. Likes Hoity liked this post
  5. #3
    Mar 2023
    Miami, Fl
    Here are a few pictures of the Godzilla motor when they were getting it all together in Proformance Unlimited
  6. Likes Mike.Bray, Railroad, Hoity liked this post
  7. #4
    Senior Member Pat Landymore's Avatar
    Dec 2018
    SW Calgary, AB
    Very Nice!!
    I’ll be logging on from time to time to follow your project as you progress.
    And, once done…enjoy that big block power! 👍🏼😁
    Once again with an 88 mm Turbo, Big Block Chevy powered, ‘35 Hot Rod Pickup
  8. Thanks Jespinosa thanked for this post
  9. #5
    cv2065's Avatar
    Dec 2017
    Almost went this path but wasn't quite baked at the time. I'm assuming you went with the Indy Products oil pump conversion kit? I look forward to your build!
  10. Thanks Jespinosa thanked for this post
  11. #6
    Senior Member Its Bruce's Avatar
    Houston TX
    Love the Godzilla and looking forward to seeing the build progress.
    MK4, 427LS3, IRS, T56 Magnum, Wilwoods
  12. Thanks Jespinosa thanked for this post
  13. #7
    Apr 2021
    Park Ridge, IL
    Very nice! I'll be following along.
  14. Thanks Jespinosa thanked for this post
  15. #8
    Oct 2023
    Just did this in a type 65 Godzilla and T56 magnum... You will probably need the Indy Power Products cobra pan, I experimented with a different pan and it hung down 2" below the body chassis. If you need help reach out.
    I made the headers and motor mounts, you can check out the video on my YouTube CWI Performance.
    I also assume you will be using the Jolt Harness? If you use the new BTR cam and lock out it will make 600/600 ish, I have a godzilla in my Foxbody that makes about 1400hp and we track it on road courses.
  16. Likes Pat Landymore, Hoity liked this post
  17. #9
    Mar 2023
    Miami, Fl
    Not sure exactly what kit was used to be honest, since I did not originally order the engine, but it isn't the stock oil pan and has been modified.
  18. Likes Hoity liked this post
  19. #10
    Mar 2023
    Miami, Fl
    Quote Originally Posted by Bob Folkestad View Post
    Which pan did you experiment with?? I am not sure which one was used in my application as I did not order the engine, but it didn't look stock. The engine is currently in a warehouse owned by a family member to give me more space in my garage until I need it.
    One quick question, I was thinking of using the stock exhaust manifolds and flipping them to opposite sides and doing a custom j-pipe to the side exhaust. Did you ever contemplate this idea?
    The harness was prepared by the engine builder to work with the Holley Terminator x-max computer. I don't think there was any off the shelf stuff at the time, so he worked with Holley and made his own harness to get it to work. As far as it having a Jolt harness, I honestly have no idea.
    I watched the CWI Performance video and subscribed to future videos. The type 65 with the Godzilla and the Innov8 ITB's looks amazing. I wish I could do custom headers myself but creating headers is definitely past my mechanical ability. Keep up the good work.
  20. Likes Hoity liked this post
  21. #11
    Dec 2021
    Flower Mound TX
    Quote Originally Posted by Jespinosa View Post
    Have you reached out to Gas N about headers? Georgie might be able to help you.
  22. #12
    cv2065's Avatar
    Dec 2017
    There are two choices now. Indy products which is very proprietary and Holley, which made theirs more 3rd party friendly. Holley's system is about 1/2 of what the Indy program cost. Either way, you are relocating the oil pump to the front as a chain driven system with a low profile oil pan. I'm not sure if anyone has created motor mounts that you can just buy, so you'll want to look into that maybe with Mike Forte. Georgie with Gas N Pipes was looking to make a version of headers and pipes for the Godzilla but I think someone will need to order his Frankenstein system and help him create them from scratch once the engine is installed. You'll also have to modify the drive shaft. Mike Forte might be able to help with that as well. Not sure which harness you'll be able to use with little fuss, but I think OBR makes the best option at this point.
    I attempted to get more info from the Backdraft people, as they have put the Godzilla in their cars, but they won't help you. Not even a little. I do know that they use the Indy system.
  23. #13
    Mar 2023
    Miami, Fl
    I did reach out to him last year and he didn't seem to be interested in making headers for the Godzilla.
    I might reach out to him again in the future to see if that has changed.
    Thanks for the suggestion.
  24. Likes Hoity liked this post
  25. #14
    Mar 2023
    Miami, Fl
    Forte is working on some motor mounts for me as we speak.
    When the motor was ordered from the engine builder it was built with the intention of putting it in the Cobra. But the engine was built more than a year ago and a lot has changed in the aftermarket since then for the Godzilla. I need to confirm how much clearance actually was gained by the modification to see if I might have to use another method like the one's you mentioned. Hopefully not as it get expensive real quick.
  26. Likes Hoity liked this post
  27. #15
    Oct 2023
    Backdraft cars are way different than Factory 5, SuperPerformance adn Backdraft both use the 7.3, Call Jim at INdy and he can help out. The holley pan is about 3-4" too deep to work correctly in these cars, it's already been tried. FWIW I own the machine shop that builds most of Indy's products. OBR or Holley will work fine for an ECU, OBR is easier and probably better especially with Individual Throttle bodies. Get a Fabricator to make the headers, I thought we could take the Type 65 and make some swap parts at my shop but putting the Godzilla in it was a little advance for most home builders. I had to move some tubes on the chassis to do it right.
  28. Likes Railroad liked this post
  29. #16
    Mar 2023
    Miami, Fl
    It has been a while since I posted anything, but I might as well update everyone on some of the previous work that has been done. This work was done a few months back, but I figure it would be good to post it. My kit came with the Wilwood brakes for the front, so I put together the front rotors as per Willwood's instructions:
    I finished installing the rotor and brakes on both sides.
    And finished most of the front suspension installation. Now would have been a good time to check if the steering rods fit in the arms but unfortunately, I did not check this and I had to take this all apart in the future.
    The last pics is of the differential that came with my kit. I took a picture to figure out the gearing. From the looks of it the gearing is 3.55 but the kit was order with 3.73 speedo gear which had me questioning it. The kit must have been ordered with the 3.73 gear in mind and the Seller changed their mind when they purchased the differential in the future?? Who knows....the endless mysteries and fun of buying a kit of someone else.
  30. Likes Hoity liked this post
  31. #17
    Yes, that's a 3.55 diff. Factory Five has only ever sold 3.55 diffs. They sell the NIB M-4001-88355B from Ford Performance. That's the only version Ford Performance currently sells. In 2017, when I build my Coupe, Ford Performance was still selling a 3.73 Torsen (M-4001-88373T) but they discontinued it. I was able to get one of the last ones. Even when it was available, I never saw that version offered by Factory Five. So I question whether there was an order for a 3.73 from Factory Five.
    Having said that, the picture posted appears to be a used one. Nothing wrong with that. Lots got that way.
  32. Likes Hoity liked this post
  33. #18
    Mar 2023
    Miami, Fl
    The diff was not purchased from Factory 5 as it wasn't included in the original PO.
    What confused me was the inclusion of the 3.73 gear in the PO, which if I recall doesn't get used since I have GPS gauges??
    Thanks for the clarification on the gearing Edward.
  34. Likes Hoity liked this post
  35. #19
    I misunderstood your post. Sorry.
    Right. With GPS gauges, you don't care about speedo gears, tire sizes, whatever. Just hang the antenna and go.
  36. #20
    Mar 2023
    Miami, Fl
    No need to be sorry as your expertise is greatly appreciated.
    I wrote on my post that the diff came with my kit, so your response makes total sense.
    Thanks for the confirmation on not needing the speedo gears.
  37. #21
    Mar 2023
    Miami, Fl
    Unfortunately, one of the pitfalls of buying a kit from someone else is the jumbling of parts. The kit already is a large mix of parts but since I bought it from someone else, I spend a lot of time looking for parts as they are not in the original box that factory five put them in. I tried to organize as much as possible and keep notes as to where some parts are, but sometimes certain parts really enjoy being extra hidden.
    Case in point the brake parts. I am at the point where I am trying to run the brake lines and I cannot seem to find the brackets for the front flexible brake line to the frame. I found the corresponding bag but I cannot find the brackets. Here is what I found in bag 11076 which should have the brackets:
    Unfortunately, some of the fittings inside the Willwood brake line kit are rusted already and I don't feel comfortable using them:
    These are the brackets from the rear but I do not see any of these for the front:
    So it seems that I am missing some parts or am I supposed to use the triangular brackets that the instructions say not to use??
  38. #22
    Mar 2023
    Miami, Fl
    It has been quite a few months since my last update, but I have been quietly working on the build when I have the time. I will upload some pictures in the next few days of the progress. For this post I wanted to update everyone on the engine installation and ask a few questions to make sure I am on the right track. Using the engine mounts provided by Mike Forte, I have been able to roughly put the engine where I think it should go. Now I am no professional by any means and am surely making a few educated guesses.
    My first question is regarding the hood clearance from the 3/4" bars. I know that the body gets installed on the bulb seal and the hood is set a little higher but about how much clearance do I have from the top of 3/4" bars? For some reason I member it being about 3/4" but I couldn't find that info again.
    In this photo I placed a 2x4 on top of the 3/4" bars and measured the distance from the engine plate to the bottom of the 2x4 and it is about 4 1/4" from the engine plate. This is the reason for my first question as I need to make sure my intake will clear since it should be 5" at its highest part.
    My second question is what is the maximum distance from the bottom of the 3/4" bar where the transmission tunnel starts to the middle of the pilot bearing or where the transmission is installed? The reason I ask is because I am going to have to raise the engine to clear the oil pan. According to my current measurements there is 5 1/4" from the 3/4" bar till the middle of the pilot bearing. This might not be something that is usually measured but I figured I would ask.
  39. #23
    Mar 2023
    Miami, Fl
    I had a few forums members answer my question in another post, so I should have enough room to fit the oil pan above the 4" round frame and make it under the hood. Amazing news as I had been worried for months and it seems like it is going to work.
    While I am waiting for the motor mounts to be adjusted, I decided to work on installing the flywheel, clutch and transmission to make sure the whole package fits. From my research I might need to adjust the drive shaft but until I mock everything up, I will not know for sure. So, I started working on installing the flywheel but in order to install the flywheel, I needed to get my Quicktime bellhousing down from the attic in order to install the plate behind the flywheel. I went back to my inventory list to see if I had seen the flywheel bolts, but I did not see any mention of them on my inventory list anywhere. I was hoping they would be packaged with my flywheel but that was not the case. After researching online, I found out that the Godzilla uses similar bolts to the Coyote so I ordered a kit that should work. Flywheel Bolts.jpg
    The bolt size and thread pitch are perfect at M10x1.00 but the size was not. It seems that these bolts work with the flexplate which is much thinned than my flywheel. When I went to install the flywheel bolts I only had about 5-6mm of the thread engagement. flywheel bolt spacing.jpg
    I measure with my calipers and I have about 33mm from the flywheel to inside of the crankshaft. The bolts that I purchase where 23mm and were tapered at the end. Some more research later, I was able to find some arp studs for a 6.4l Diesel that have a M10x1.00 that are 1.275 inches long (32.4 mm). https://arp-bolts.com/kits/arpkit-de...?RecordID=4934
    I called ARP and they think it should work. I ordered them and the bolts should be here tomorrow. I guess since the Godzilla's all come with an automatic there is no specific bolts made for them when you have the manual instead. Regardless this is all a new learning experience, and it seems that there will be a few more of these hiccups as the build goes on.
  40. #24
    Dec 2021
    Flower Mound TX
    Anytime I have shallow and/or blind tapped holes whether in my hobby or my machine design at work I go with studs. Usually installed with 242 blue Loctite. Only way to insure full thread engagement. As an added bonus, in a lot of situations studs make assembly easier.
  41. #25
    Mar 2023
    Miami, Fl
    I decided to add brake fluid to my Scott's triple reservoirs this weekend and check my brake line work. Considering I had never run brake lines in my life and that I decided to cut and flare the lines, I was quite worried that it wouldn't work. To my surprise it went pretty well. I had a few small leaks in fittings that weren't fully tightened but that is expected. My son helped me by pumping the brakes while I opened the valves in all of the corners. We were able to get 3 of the 4 sides done, but we could not bleed the driver side front caliper. I even jumped in and started pumping the brakes myself to no avail. I tried not to get frustrated and decided to circle back in the morning. Without my assistant, I tried again multiple times and still never saw any fluid come out of the Willwood caliper. By this time, I knew something wasn't right. I loosened the flexible brake line connection to the Willwood caliper, and no brake fluid came out. I then loosened the connection from the flexible line to the fitting on the firewall and the fluid started coming out quickly. I checked both ends of the flexible lines and I did not see any blockage. After some quick research on Google and Youtube, the recommendation was to use air pressure to push any potential blockages out of the lines. I added some pressure on one side and the pressure gauge on my pump immediately shot up to 70 psi and stopped. The blockage remained. After multiple attempts, I decided to call Willwood to inquire about a replacement flexible line and the tech support said he would send me a new line free of charge. He sounded surprised that the line was blocked and informed me that this was the first time he had received a call regarding a blocked flexible brake line. So, I guess I am either really lucky or he hasn't worked in Willwood real long, lol. Regardless he was very helpful, and I should receive the line by the end of the week.
    Now on to another problem, my reservoirs started leaking from the bottom very slowly. I have my brake lines coming from the back of the reservoirs and plugged the bottom of the reservoirs with the appropriate fittings. The problem is one of the fittings keeps leaking very slowly, like 1 small drop every few hours. I am afraid of over tightening the fittings as they are aluminum, and the Allen key will eventually strip them. Can you use any type of ptfe or sealant that will not get destroyed by the brake fluid to further strengthen the seal? Has this happened to anyone else with the Scott's triple reservoirs?
  42. #26
    Mar 2023
    Miami, Fl
    I was finally able to install the engine in the car this weekend, but I realized that I forgot to add the photos from my previous failed attempt. Here are some photos from a few weeks ago.
    Once I had the engine mocked up with the original motor mounts sent by Mike Forte, I had noticed that the motor mounts needed to be adjusted to add some additional height to the motor for the oil pan to clear. Mike Forte asked me to send him the mounts back to adjust them and quickly turned around the revised mounts picture here:
    With the new mounts, I was able to install the Godzilla to the frame. What a great feeling!!! Finally, the motor is inside the engine bay!!
    I put the stock intake for the time being, but I plan on buying the Holley intake that lowers the intake by a few inches and should clear the hood as per my previous post. Here are some picture of the engine installed:
    Engine Passenger side.jpgEngine Install front.jpgEngine Install Driver Side.jpgGodzilla Pulley Assembly.jpg
  43. Likes rustyrim liked this post
