Good afternoon all,
I'm attempting to install the e-brake cables and if I follow the directions the cable from the rear brakes is way too short. If I run the cable to the holes in the transmission tunnel the inside cables themselves are way too long, not to mention the e-brake cable has to go VFR direct over many of the moving parts of the axle. It appears the directions have a piece welded to the rear axle frame but I do not have that on my frame however based on the length of the cable if that bracket was there it would work.
Thanks, Ron
