Thanks Thanks:  2
Likes Likes:  2
Results 1 to 9 of 9
Thread: Intermittent problem starting
    Nov 2018
    CT
    Hi all,
    I have a Roadster with a Gen 3 Coyote and TKX. All new parts with about 100 miles on the odometer. I have recently noticed that on occasion I turn the key and it cranks for about two seconds and then stops cranking. Fortunately each time this has happened I have been able to turn the key to the off position and try again and on the second attempt it cranks until the engine kicks over. When cranking it sounds strong. The battery is fully charged and it has happened when the engine was both hot and cold. I originally thought that I may have not had the clutch in far enough to activate the clutch safety switch, but have since confirmed that this was not the case (it happened with the clutch pedal all the way to the firewall). Any thoughts on where to start with diagnostics?
    As always, much appreciated.
    Tony
    Are this issues occurring on hot and/or cold starts?
    Nov 2018
    CT
    Yes, it has happened when the engine is both hot and cold.
    FFR MKIII builder/owner
    Nov 2012
    Danbury Ct.
    Sounds more like an intermittent connection problem in the crank circuit.
  5. Thanks Tbev thanked for this post
    South Australia
    1. to eliminate an issue with the starter motor, run a test light from the starter solenoid terminal.
    2. are you using the neutral safety switch? If so, check for correct adjustment / operation.
    Gen1 Coyote / TKO600 / IRS
    Nov 2018
    CT
    Thanks Nigel.
    I'll start with checking to make sure the neutral safety switch is adjusted properly as this was what I had originally thought was the likely cause. I have doubts though because when I turn the key off and back on I do not release the clutch pedal and push it back in. I keep the clutch pedal all the way to the floor and on the second turn of the key it works.
    If all looks good there then I will try your first suggestion.
    Thanks again,
    Tony
    Senior Member Lidodrip's Avatar
    May 2020
    Yarmouth, Maine
    Might be the ignition switch since that is what you are manipulating to get it to eventually start.
  9. Likes Nigel Allen liked this post
  10. #8
    Nov 2018
    CT
    Quote Originally Posted by Lidodrip View Post
    That thought had crossed my mind as well. The wiring behind the dash is so tight, maybe there is an issue there. I will check it out. Thank you!
  11. Likes Nigel Allen liked this post
  12. #9
    South Australia
    Sticky starter solenoid is highly possible. Starter will not get power, unless solenoid pulls all the way in.
  13. Thanks Tbev thanked for this post
