Intermittent problem starting
Hi all,
I have a Roadster with a Gen 3 Coyote and TKX. All new parts with about 100 miles on the odometer. I have recently noticed that on occasion I turn the key and it cranks for about two seconds and then stops cranking. Fortunately each time this has happened I have been able to turn the key to the off position and try again and on the second attempt it cranks until the engine kicks over. When cranking it sounds strong. The battery is fully charged and it has happened when the engine was both hot and cold. I originally thought that I may have not had the clutch in far enough to activate the clutch safety switch, but have since confirmed that this was not the case (it happened with the clutch pedal all the way to the firewall). Any thoughts on where to start with diagnostics?
As always, much appreciated.
Tony
Are this issues occurring on hot and/or cold starts?
Railroad
Yes, it has happened when the engine is both hot and cold.
Sounds more like an intermittent connection problem in the crank circuit.
Tbev thanked for this post
1. to eliminate an issue with the starter motor, run a test light from the starter solenoid terminal.
2. are you using the neutral safety switch? If so, check for correct adjustment / operation.
Gen1 Coyote / TKO600 / IRS
Nigel Allen
Thanks Nigel.
I'll start with checking to make sure the neutral safety switch is adjusted properly as this was what I had originally thought was the likely cause. I have doubts though because when I turn the key off and back on I do not release the clutch pedal and push it back in. I keep the clutch pedal all the way to the floor and on the second turn of the key it works.
If all looks good there then I will try your first suggestion.
Thanks again,
Tony
Might be the ignition switch since that is what you are manipulating to get it to eventually start.
Lidodrip
That thought had crossed my mind as well. The wiring behind the dash is so tight, maybe there is an issue there. I will check it out. Thank you!
Sticky starter solenoid is highly possible. Starter will not get power, unless solenoid pulls all the way in.
