Wheel Well Liner
Anyone use the gator grip or similar undercoat product on the inner fenders (fiberglass areas) and under the nose cone to dampen rock impacts and clean up the look?
The chap that built my car left it all exposed in gel coat so I am hoping to clean it up.
I realize there are plastic insert wheel well liners we can buy however I personally am not a fan of the look, the fit, how they mount nor the access/visual access lost by what it covers. The liners also don’t address the portion under the nose cone (directly above the radiator)
Appreciate the input and product info.
Cheers
Truck bed liner (rolled or sprayed on) is what most people use. I used a duplicolor water based brush on product but hurculiner and raptor liner has been popular from other builders. Triple layered in the wheel wells for added protection from star cracks in the paint from rocks
Post Thanks / Like - 2 Thanks, 0 Likes
25th Anniversary #9772
like Chewy said - Raptor Liner is pretty popular and has several application styles
I got a few rattle cans of it to darken up the aluminum in the rear wheel wells
Doc76 thanked for this post
Anyone willing to share some pictures of the finished results?
Originally Posted by
Doc76
Do you have Princess Auto near you?
https://www.princessauto.com/en/blac...t/PA0008829129
I know you have Candian Tire
https://www.canadiantire.ca/en/pdp/r...1_rr&rrec=true
These both work. The one from CT also comes in a 4L can which you can brush on. I use that to do the whole underside of the body.
This is not a great pic but you can see the rear wheel well panel(princess spray) and the underside of the body(CT spray) in that area.
MK4 #11173 picked up 01/20/25
MK4 #11012 picked up 04/16/24
MK4 #10616 picked up 4/10/23 SOLD
MK4 #9759 picked up 4/3/19 SOLD
Higgybulin
Yes I have both.
In fact I have a can of that CT spray in my shop but wasn’t sure of its longevity. (Used it on an enclosed trailer).
How long have you had it on?
Did it go one with a decent thickness? (I found it to be quite thin regardless of coats.)
I spray it on the underbody with a shutz gun
Higgy
Post Thanks / Like - 1 Thanks, 1 Likes
Wingman06
Great video. Thanks for taking the time to make and share this as well as responding to my question
Cheers
I purchased a set of wheel well liners specifically designed to fit the Mk4 Roadster from Raptor Speedworks. Easy to install, they lend a very nice finished look to the wheel wells and absolutely protect the under body from road bits. I got the recommendation from a fellow in the Atlanta Cobra Club who pointed out a spider crack on the top of the front DS fender. Although he installed the guards after the fact, he is happy there will be no additional stone strikes. Luckily, I installed a set early on before any impact issues.
Art Shand, Big Canoe GA
BPE 347 FI, Hydraulic Tremec TKX, Wilwood front & rear, GAS-N Headers/Touring Pipes, many functional upgrades.
Theshandman
I’ll check them out. I too have one of those cracks.
Can anyone tell me what size the bulb seal is on the inner fender well rear panel?
Guy that built my car cut it way short.
