Thread: Door window seal
    Mar 2021
    Bradenton, FL
    Door window seal
    The provided door window seal look terrible once I got it installed....maybe i screwed it up, who knows. What have others done other then the FFR provided rubber/felt seals?
    I spent a long time fiddling with it. I looked for alternatives but didn't find anything so just got through it. Eventually turned out OK.
    Mar 2021
    Bradenton, FL
    Thanks Mike, Il STBY for more info from others.
    Placitas, NM
    Same problem with the 33 Hotrod windows.
    Oct 2022
    I found the seals to be quite straight forward on my Speedstar. The seal around the opening on the roof does not have felt on it. Only the seals in the top of the door on either side of the glass have the felt.
    Mar 2021
    Bradenton, FL
    Your car is different than the truck. Truck has trim around all 4 sides on the DOOR. Thats the issue.
    Mar 2021
    Bradenton, FL
    My solution finally! I ordered a new set from FFR and will have my glass guy install it. That should brevent most of the self imposed screw up's.:-)
