Results 1 to 4 of 4
Thread: Oil pressure gauge sending unit
    Falmouth, MA
    Question Oil pressure gauge sending unit
    I have the FFR gauge set supplied with the Coupe and the oil pressure sending unit has failed. The gauge was working fine, now always goes to 100 psi and doesn't move. I have checked the pressure with a manual gauge and all is fine. There is no name on the gauge or on the box the gauges came in. Where can I obtain a new sending unit?
    South Australia
    Can you post a photo of gauge and sender?
    How many wires to sender?
    Gen1 Coyote / TKO600 / IRS
    South Australia
    If the gauges are Speedhut, then these are your sender options:
    https://speedhut.com/categories/acce...e-sensors.html
    I have found these guys to be great to deal with.
    Falmouth, MA
    I'm not sure if they are speedhut or not as there is no name on the gauges, the sending unit or the box they came in. I live only about 10 miles from FFR so maybe I'll pull the sending unit and drive over to see if anybody there can help me out. Thanks for your help!
