Brake Pedal Switch Issue (I think lol)
Well now that i am into final assembly, i installed the rear tail lights.
Went to test the brake pedal and it blew the fuse under brake/four-ways. I tested the four ways first, no problem. then brakes and pop. Worked before bodywork lol.
Any quick thoughts? Should i just get another switch?
Thankyou
Nelson
I wouldn't think it is the switch since the fuse blows when you apply the brakes. I would guess you have a wire that is shorted to the chassis.
Yes, sir, not the switch. I found that i forgot to cover the exposé positive and negative terminal on the brake lights. they were touching.
