Results 1 to 4 of 4
Thread: Brake Hose Mounting Tabs and Clips
    Oct 2019
    Erin, Ontario CANADA
    Looking for these.
    I found the back ones, they were in box #22, bag #14754, part numbers are 14689 and 14709.
    The front ones I can't find anywhere and they are not showing in the Kit Pack List at all.
    Note that I purchased my kit without brakes. If I did would the corresponding front pieces maybe have been in with the front calipers?
    To keep going are the front and rear parts interchangeable?
    Earl
    20240929_211457[1].jpg?
    Dec 2017
    Southern Ontario/Cape Coral FL
    They look the same to me. I am sure you can make them work.
    Higgy
    MK4 #11173 picked up 01/20/25
    MK4 #11012 picked up 04/16/24
    Oct 2019
    Thanks, I have since been advised by others that unless you order brakes they aren't included. IMO a little inconsistent, as the back one were.
    Earl
    Oct 2022
    The retaining clips are available at most parts stores. The mounting tabs are available from Speedway Motors.
    FWIW, I got the standard Mustang GT front brakes with my kit and got two mounting tabs. Since I was sourcing my own rear axle I had to source brakes, hoses, mounting tabs and clips
