Thanks Thanks:  7
Likes Likes:  2
Results 1 to 9 of 9
Thread: Gravel Guard on Brake Lines?
    Jul 2024
    BC, Canada
    Hey guys
    I am running some new nickel-copper brake lines and wondered thoughts on the gravel guards.
    I see some guys use it, many don’t.
    Thoughts?
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    Everyone that doesn't have them will tell you they're not needed, and everyone that has them will tell you that they're good peace of mind.
  3. Thanks Doc76 thanked for this post
    Likes PNWTim liked this post
    Senior Member Kbl7td's Avatar
    Apr 2022
    Miami
    I did it on my coupe because it just looks better. Not a single line is anywhere near danger on the coupe. Can’t speak for the roadster.
  5. Thanks Doc76 thanked for this post
  6. #4
    No, not needed. Almost 20 yrs on the road and never a mark on any line.
  7. Thanks Doc76 thanked for this post
  8. #5
    Had it on my first build because I thought it looked better. Haven't used it since. Not needed IMO but I'm the last one to criticize extra work just because I think it looks good.
  9. Thanks Doc76 thanked for this post
    Likes cc2Arider liked this post
  10. #6
    Not necessary in my opinion but if it makes you feel good go for it!
  11. Thanks Doc76 thanked for this post
  12. #7
    May 2023
    Mine were used to make my sloppy bends look a little better!
  13. #8
    I used it because it came with my tubing. There is one spot on my lines that I felt needed protection based on the condition of the coated metal in that area, and that is where my rear line comes out under the footbox. It seemed pretty exposed to road grit, so I created a "skid plate" shield for that spot.
  14. Thanks Doc76 thanked for this post
  15. #9
    Member Sarcasticshrub's Avatar
    Dec 2021
    Mariposa, CA
    I liked the look and the extra protection from the types of road junk around here. Not necessary for sure but me likey.
    Stuff was inexpensive so I did the rear brake and both fuel lines.
  16. Thanks Doc76 thanked for this post
