London Cobra Show
Thread: Both front turn signals flash
    Apr 2024
    Hi guys..newbie here! we're building a 35 ff pickup. just installed the led headlights and when i put the right or left turn signal on, both of them flash? what am i missing here?
    Port Charlotte, FL
    If you only used one indicator on the dash, you need to put a diode in otherwise this will happen.
    Henry
    Apr 2024
    thanks Henry
    i should have mentioned that i don't have the dash in the car yet and i meant turn signals both flash, not the actual headlights...
    Johnny
    Jun 2018
    North Vancouver, BC, Canada
    The 35 pickup and the 33HR are very similar, identical when it comes to electrical... The wiring harness is "universal" to FFR kits and different things need to be done to get it to work in the different models. Make sure you following instructions in the separate wiring manual as well and the '35 manual. For the 35 and 33, there are a few wires to cut and, if I'm remembering correctly, you actually need the dash harness plugged in for everything to work properly....
    Gen 1 '33 Hot Rod #1104
    Apr 2024
    thank you Steve. im going to put the dash in after lunch...ive cut the wires shown on the dash harness side...ill see what happens
    Jun 2018
    I think there was another mod around the steering column wiring as well... Steve
    Apr 2024
    that could be my issue
    I did the truck build with the RF harness, Ididit column, Hot Rod connector, LED lights, etc. If you have the wires in the dash harness accounted for per the build manual, it should work. There were no other mods and as I recall doesn't require the dash harness to be installed. Did you install indicator lights for the turn signals? They need to be properly separated as Henry noted. Make sure you have the wires to the LED's correct. There's a separate color to each corner. Assuming everything else is right, the GM turn signal switch in the Ididit column is another place to check. Mine was intermittent and I had to replace.
  9. Likes Bobshotrodshop317 liked this post
  10. #9
    Apr 2024
    hi guys! thank you for all your responses...turns out it was a faulty turn signal switch! now onto getting this truck on the road!
