Cutting all the holes for gauges, switches and indicators went pretty smooth. I realized that I was not going to be able to install the wiper switch and headlight switch to the left of the steering wheel. They interfere with the frame support under the masters. I had used blocks of wood taped to the back of the dash to check for interference.
So I moved the headlight switch to the right of the column and moved the wiper switch up.
The indicator lights are hard to see, but the "arrows" are left and right of the gauge cluster. The highbeam blue light is to the left of the headlight switch. Under the gauge cluster is a read check engine light.
Since taking the above photo I also got the defrost vents installed.
The Vintage Air controls (oval control panel from Vintage Air) will be mounted in the center console along with window switches.
