X2 on 347 for 450ish hp. I used the Mahle PowerPak pistons for just over 10.5:1, AFR CNC Renegade heads, custom Bullet cam, Edelbrock Performer RPM Air Gap, and QFT 650 to hit 450 hp. I did spend the coin on an internally balanced forged crank and rods which is probably overkill as Stangracer suggested. I used the PowerPaks in 2 motors in summer 2023–only problem is the damn wire locks-my fingers still hurt![]()
BUDFIVE
Complete kit order 8/28/2023
347 Ford Dyno 10/12/2023
Kit Delivery 11/28/2023
First Start 7/4/2024
Go Cart 8/31/2024
I really like Dart blocks. The only real difference between the Iron Eagle and SHP is the Iron Eagle has 4 bolts on all five mains where the SHP only has 4 bolts on the center three mains. There are some differences in oiling provisions that really only make the Iron Eagle advantageous when using a dry sump system. The Iron Eagle also comes set up where you can restrict the oil to the top end but this could easily be done with a SHP if needed. Once you build engines with Dart blocks you will never want to go back to stock blocks. I just finished building a short block for a fellow road racer last week that used a stock block with a girdle and HATED every minute of it. The girdle got in the way of everything. I must have had it on and off at least 20 times while measuring the main bearing clearances. He didn't appreciate it when I told him the only thing the girdle does is holds the block together when it splits...
The FRPP Boss blocks are nice too. The knock on them is they have shorter cylinders so the pistons come out of cylinders more at the bottom of the stroke and can cause the piston to lose stability. This is not an issue if you have a piston designed with the correct break point. If you find a good deal on a FRPP Boss block I would not shy away from it due to the shorter cylinders...
The World Products blocks are nice too. I have never used one, so I can't comment with personal experience, but they look good on paper.
If you are going to step up to one of these blocks, then I would suggest going with a forged internally balanced crankshaft. When spending this kind of money stick with either an ATI balancer or one from Innovators West. I would still stay away from the heavy rods and look for a reasonable lightweight I-beam rod. Again, the Mahle "PowerPak" pistons would be a good choice. They have a 1mm/1mm/2mm ring pack and are made of 4032. 4032 is a better material for a street engine as it allows you to run tighter piston to wall clearance and will maintain ring seal for a longer period of time. However, 4032 is more susceptible to be damaged if you get into detonation.
Any 190 cc volume runner cylinder head should be able to easily achieve your horsepower goal with a custom ground cam and 10:1 - 10.5:1 compression. I really like the TFS Twisted Wedge heads. They are advertised as a 170 cc runner but the intake valve is closer to the intake side of the head, so the runner is shorter. It has the cross section of a normal 20-degree 185-190 cc head. The thing I really like about the TFS Twisted Wedge is it has a very efficient chamber, so you don't have to run a bunch of timing. Usually, 30 degrees total will make the most power. In addition, the TFS head has flatter valve angles which helps with piston to valve clearance. Keep the quench tight, around .040 or even .035 if you don't rev it over 6500 rpm, and you may be able to get away with 11:1 on 93 pump gas if you keep the AFR around 12.8 - 13.0.
I’m in the process of weeding through several engine builders locally.
Sourcing a crate setup out of the USA is simply too expensive with the exchange rate for us up here.
It’s a learning curve.
AI is proving to be a powerful tool for analyzing a proposed build sheet. Not sure if anyone else here uses it but I use AI for increasing amounts of data analysis. Saves hours of Googling![]()
Quote: "But buying a runner was my best bet"
That is absolutely TRUE! It is sad, it is ironic, but it is true. Building a car has become expensive....ESPECIALLY the paint and body work. In my own case, I could build the car competently but NOT the body work. I was lucky, I looked for a while and found a low mileage well-built Mark II with a 427W and TKX. Beautiful paint and all the upgrades I wanted with none of the upgrades I didn't. Ironically, it would have cost me twice as much to build it as I paid for it. Of course there is a downside to it. Firstly, I don't know the car inside out. I have to acclimate myself to the car as I address issues whenever they arrise. And also, I don't have quite that feeling of pride and joy and satisfaction that comes with building your own from the ground up. But the "sum of the parts" is more than the value of the whole. I just could not afford my car if I had to build it. Irionic, to say the least.
Yes I did the math over and over and it was crazy that I could buy the car for the price of the parts.
Now yes, there are a lot of other things to consider but I mean for a person on limited time, resources, etc, it really only makes sense to buy a runner if you can find the right one.
As I said, I’m sure after retirement I’ll build one but that’s 10-15 years away.
