Page 3 of 12 FirstFirst 12345 ... LastLast
Results 81 to 120 of 478
Thread: What did you do on your GTM today?
    Member kabacj's Avatar
    That's awesome Joel. You beat me to it. I had my first opportunity to drive an indy car last year and I just have to have one. The performance is just amazing. The perfect blend between a motorcycle and car. Sadly, I have been banned from getting any other projects until the gtm is complete.
    What chassis is that? Looks like a late 80s March Penske? I have been looking at 1200 cc motorcycle motor powered cars as I don't want a car that has lots of expensive hard to find components. BUT if the right car comes along...
    Congratulations. Nice purchase.
    XTF #2
    build start date June 19 2023
    GTM # 344
    Build Start December 2010
    First track day April 2013
    Member JCHRacer's Avatar
    That's awesome Joel. You beat me to it. I had my first opertunity to drive an indy car last year and I just have to have one. The performance is just amazing. The perfect blend between a motorcycle and car. Sadly, I have been banned from getting any other projects until the gtm is complete.
    It's actually a Swift DB-4 Formula Atlantic. 1.6 ltr Toyota engine so the cost is not hateful. Lighter than an IndyCar but makes less power (~280 HP). Still it's REALLY fast. Should be fun.
    Ciao,
    Joel
    Working ever so slowly on GTM #269, Twin Turbo SBC, Ricardo, Kit arrived April 5, 2009
    http://photobucket.com/JCHRacer_GTM_Build
    San Diego
    IIRC an Atlantic car is what holds the overall track record at Thunderhill, where the 25 hour race is held every year. Atlantic cars are WICKED fast, but the engines do require a bit of maintainance. Not sure I would feel real safe running one at speed with others on the track though, and depending upon the track layout, I might not even feel safe running it by myself! Great car though.
    My former employer bought an ex Gurney 1996 vintage Indy car for $40k with TONS of spares. It was almost two cars worth of stuff.
    There are certainly some "deals" to be had on race cars right now.
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
    Senior Member VD2021's Avatar
    Central, FL
    Took the GTM down from the jack stands Sunday after almost two months. Took it for a drive this evening, around the neighborhood, to test the magnasteer power steering addition.
    R/s
    Vidal
    BUILD LOG AND WEBSITE:
    http://gtmbuild.weebly.com/ .
    Cape Cod
    Picked the final color. I will say it will be one of a kind.
    Senior Member Edgeman's Avatar
    Medicine Hat, Alberta Canada
    I had installed the fix for the belt pulley from Shane At VRaptor. I had to get my lathe out and cut it into two pieces, then machine the ends down. With out the lathe would have been hard to get them straight. Also had ordered the hatch props will install at a later date. Thanks again for the great work Shane.
    GTM #370
    Car was completed and I have SOLD my car
    http://edgemansgtm.weebly.com/index.html
    Doing what you like is freedom - liking what you do is happiness
    later,
    Doug
  7. #87
    Caldwell (near Boise) Idaho
    Put the motor in tonight. Puts new meaning to the word shoehorn. The motor was a thing of beauty. Headers, ac pump, serpintine system, and thermostat had to be removed to get the engine in. At least I didnt have to remove the clutch. Now that the motor is in I get to put all those things back in.
  8. #88
    Awesome Roger! Not long till you are lighting up those slicks!
    XTF #2
    GTM # 344
  9. #89
    Senior Member rev2xs's Avatar
    Wysin, Poland
    How was it?
  10. #90
    Central, FL
    Quote Originally Posted by rev2xs View Post
    How was it?
    Just like it was in the donor.
    The effort required to turn the wheel, while not moving and at low speed feels close to how it did with the manual rack. I can turn the wheel with a finger with the GTM at a standstill, but not with the ease of a luxury car.
    A lot of the feedback that was felt with the manual rack is gone and I like how it gets stiffer as the speed increases. I also like that it takes less time to get going when I back out of my driveway because I'm not turning the wheel for three minutes. Its 2 1/4 turns from lock to lock so it’s a lot quicker than the manual rack.
    It's a nice to have, but I wouldn't put it in the must have list.
    R/s
    Vidal
  11. #91
    Wysin, Poland
    Cool, how much does the magnasteer system suited for the GTM go for these days?
  12. #92
    LCD Gauges's Avatar
    Toronto, Ontario
    Sanding down more flash today, and remove tape residue. I might even order some headers!
  13. #93
    San Diego
    Vidal can correct me if I am wrong, but I believe you need all the Vette electronics to make that system work properly. It is not your average build we have here.
    www.myraceshop.com
    GTM solution kits
  14. #94
    Central, FL
    You're correct.
    The EBTCM controls the a magnetic actuator that varies the steering effort, but the rack requires the entire traction control system to function fully.
    R/s
    Vidal
  15. #95
    Senior Member mikespms's Avatar
    North Miami,FL
    You're correct.
    I am not shure if you can, but you might be able to make it work with out the body control module. In the corvette all system modules comunicate thru the star connectors and the bcm connects to the data link. you would need to bypass the bcm and a link from the ebtcm to the pcm and use the harness of the ebtcm that conects to the abs, traction control and steering sensors inputs and outputs with the magnasteer rack also need the corvette engine driven p/s pump.
  16. #96
    Central, FL
    Quote Originally Posted by mikespms View Post
    It may be easier to just keep/add the BCM. It may work, but I don't think I'd add it without the complete system. The steering wheel position sensor and the lateral accelerometer are two important items of the system. And if you're adding these the BCM is only one more module. If you install this without the BCM you should plan on working through a lot of trouble codes and emulating the nodes on the bus, relative to any DTC that would put the rack into a service mode. Just my 0.02 cents.
    R/s
    Vidal
  17. #97
    North Miami,FL
    Hi Vidal, You're right ,but when I rerouted the wiring I think that all of those sensors run to the ebtcm as an independent system and use the bcm as the link. But the best safe and easy way is to use the complete corvette system like we did, it was just an idea that it might work as a stand alone .
  18. #98
    Central, FL
    Yeah, I concur. Especially when something as simple as unplugging the hazard swt causes a DTC and the system to go into service mode.
    R/s
    Vidal
  19. #99
    Got the transaxle installed. What a bear.
    Now I can measure the axle length.
  20. #100
    Central, FL
    Met Spdmon2791 and Jeremy of Fastproms. Kbentzel was also there with his GTM.
    R/s
    Vidal
  21. #101
    Senior Member sk7500's Avatar
    Installed one of ShanesAC “Blower Relocate” Plenum
    Wish I could say it was as easy as changing a tire but it wasn't. I can say it was 10 times easier than putting in the ABS cover that came with the kit. The only hard part is our car is almost ready to put the body back on and it's kind of awkward working and arms length in the foot well. But the Shane's kit was well worth the money and I wish is would have put it in a long time ago instead of just following the GTM instruction manual. Pulling in air from behind the radiator and trying to cool it and blow in into the interior just doesn't make sense.
  22. #102
    I got some great news today. FINALLY all the parts have arrived to complete my motor. Mast sent me this shot of the first bank of Hillbornes installed.
    XTF #2
    GTM # 344
  23. #103
    Stillwater, NY
    Those stacks are gonna look pretty sexy John, very nice.
  24. #104
    North Texas
    Ding-friggin'-DANG!!! You GO big boy!!!
  25. #105
    Central, FL
    Decided last night NOT to go with the power seats. I was planning to use the donor power seat tracks (modified) as Mike (MikesPMS) did. Mike and I (mostly mike) spent a few hours grinding/fitting/prepping one of my seats to accept the modified donor power seat track. Last night I was able to set the seat in the car, sit in it and make a decision. I also considered potential passenger fit.
    R/s
    Vidal
  26. #106
    My Dad sent these pictures on Fathers Day. This was his latest project after working on the Paddle Wheeler with the Steam Engine. I need to get back to the garage.
    GTM #370
    later,
    Doug
  27. #107
    Central, FL
    ......Nothing......Well I did stare at it for about 30 seconds when I had to grab something from the garage this evening.
    R/s
    Vidal
  28. #108
    Mad Scientist mendo's Avatar
    Sep 2011
    Meadow Vista, CA
    Bolted the rear suspension on and installed the axles to measure the distance between them to explore transmission options.
    GTM #253 In Process
  29. #109
    Minnesota
    I started working on the brake line routing. I decided to modify the front bracket the same way as RumRunner did.
    http://supercarbuild.blogspot.com/20...ket-front.html
    Delivered June 29, 2012
    Chassis 402
    Body work started (hatch & hood)
    Installing QRP fuel pump
    http://supercarbuild.blogger.com
    FB Page: Super Car Build
  30. #110
    Based on the advice from Kempo and Joe Mush I swapped out my clutch master cylinder from 3/4 to 13/16. This is the hot setup for the Mendiola Transaxle as it will prevent driving the clutch slave cylinder too far and damaging the clutch return fingers.
    The mounting bosses on the willwood master cylinders always bothered me so I removed them off the front and rear brake and the old clutch master cylinder.
    Of course that means I needed to remove them from the new 13/16 master cylinder.
    This is what they looked like before.
    and after
    Another thing that nobody sees but me, however it makes me happy.
    XTF #2
    GTM # 344
  31. #111
    Charlotte, NC
    Started working on the seat belt install. Got partially through the set up of the seat belts, and then learned that my plumbing in the house was showing signs of backing up. Called the plumber, who charged me 315.00 for 30 minutes of work to clear the blockage. Turned out that a root had grown into one of the joints on the main line going out, cause it to split. "Joe the Plumber" quoted me $1000.00 + dollars, (above the $315.00 that I had already paid), to fix the problem.
    He quoted me a rate of $177.00/hr plus materials. Estimated 4+ hours to do the work. I thought to myself, "Not in my lifetime"...
    So my neighbor and I dug it up, and replace the bad parts, and covered it back up. Took us an hour to dig it out, and about 45 minutes to change the joints and line, and 15 minutes to cover back up. The temp was well into the high 90's, and I was spent afterwards...
    Needless to say, that my time in the garage was cut short for the day... But I saved $1000.00 from "Joe the Plumber".
    Materials cost me $26.00.
    So it was a very productive day!
    The Stig
    GTM #0081
  32. #112
    San Diego
    Yeah, I'm always amazed at what plumbers charge. It's like they went to medical school or something. On the other hand, if I was a plumber, I would probably charge big $$ too as the job description usually involves dealing with other peoples...poo...so to speak.
    www.myraceshop.com
    GTM solution kits
  33. #113
    Central, FL
    Yeah. I definitely think the poo factor has a huge role in their rates.lol
    R/s
    Vidal
  34. #114
    Plumbed up the master cylinders. Purchased some banjo's and a slick banjo bolt with integral pressure sensor switch (eliminates the installation and adjustment hassle of the mechanical actuated switch). Cleaned up the look and leaves the bleeders in the correct location.
    Ciao,
    Joel
  35. #115
    San Diego
    Quote Originally Posted by JCHRacer View Post
    Plumbed up the mater cylinders.
    As in "Tow Mater"? LOL
    That banjo sensor is pretty cool. Where did you get it?
    www.myraceshop.com
    GTM solution kits
  36. #116
    Senior Member Kempo's Avatar
    Cabo Rojo,PR. USA
    Plumbed up the mater cylinders. Purchased some banjo's and a slick banjo bolt with integral pressure sensor switch (eliminates the installation and adjustment hassle of the mechanical actuated switch). Cleaned up the look and leaves the bleeders in the correct location.
    Joel,
    That same switch came stock in my Atom. I had two of them fail before making a mechanical switch an replacing that one with a regular banjo bolt. Thankfully my failures were just leaks around the plastic area where the wires come out. Others at the Atom club forum reported complete failures. This allowed all the pressure to escape from the system and a complete loss of brakes occurred on that master cylinder. If you still plan to use it do it in the rear wheels master cylinder. In case it fails you will still have some stopping power at the front.
    GenII GTM #354
    Delivered (02/09/11)
  37. #117
    Got this one at Pegasus Racing.
    Ciao,
    Joel
  38. #118
    Joel,
    Thanks for the feedback, it is on the rear brakes and I will keep a close eye on it. I have gotten good feedback from other people that have used them on their race cars without incident. Not a big fan of complete brake failure....now I'm nervous....any special circumstances involved?
    Ciao,
    Joel
  39. #119
    Cabo Rojo,PR. USA
    Not really some car like mine are cars that are used mostly at the track. In other cases they were street driven cars. The second one I installed started leaking fluid when I was bleeding the system after installing it. My car is used 90% of the time on track that is why I decided to remove that part from the car. Didn't want to have that in the back of my mind every time I braked.
    GenII GTM #354
  40. #120
    Wow! I thought I had a wasted day after breaking a window regulator. It just goes to prove. The worst day of working on the GTM is better than the best day of digging sewer pipes. On the other hand, now you have to use the money you saved on the GTM? At least that's what I would tell my wife. Sometimes it even works!
