Thanks Thanks:  2
Thread: Need a new Dash
    Member maginter's Avatar
    Jun 2024
    Westfield, IN
    Need a new Dash
    Hi -
    I have a Cobra MK1 and need to replace the dash. Will this one fit in the MK1?
    #11194 - Mk3 & Mk4 Blank Dash
    https://www.factoryfiveparts.com/111...k4-blank-dash/
    Port Charlotte, FL
    No, you need the MK1 dash. Steering shaft comes out in a different place.
    Henry
  3. Thanks maginter thanked for this post
    Mar 2014
    Crossville, TN & Punta Gorda, FL
    Buy a piece of aluminum and make your own.
    I do have a MKI dash that uses the Mustang gages that I never used.
    May 2018
    Chaska, Minnesota
    Absolutely make your own dash! On my '33 Hot Rod, I just made a template from the original fiberglass dash and fabricated my own aluminum dash, plus it gave me a good excuse to try my hand at engine turning. I have a total of $30 into this dash, plus it was a lot of fun. The dash is now the most complimented item on my car at gatherings and shows. This could also be painted, covered with a wrap or vinyl.
    Image - 2023-06-27T201348.510.jpegImage - 2023-06-27T201429.113.jpegImage - 2023-07-07T213221.741.jpegImage - 2024-10-05T093914.571.jpegImage - 2024-10-05T093921.086.jpeg
  6. Thanks maginter thanked for this post
  7. #5
    Jun 2024
    Westfield, IN
    Quote Originally Posted by herb427sc View Post
    I'd be curious to see what you have.
  8. #6
    Mar 2014
    Quote Originally Posted by maginter View Post
    That FFR dash would not work for me because I have a Flaming River Tilt steering column.
  9. #7
    Jun 2024
    Westfield, IN
    I will follow up in a PM
