Thanks Thanks:  13
Likes Likes:  18
Page 2 of 2 FirstFirst 12
Results 41 to 47 of 47
Thread: Smoke coming from driver side pipe - Good and bad news
    Maricopa AZ
    The 1250S3 gasket seems awfully small for the intake/head combo. I would think a 1262S3 would be more compatible.
    Senior Member Fman's Avatar
    Jan 2020
    State of Jefferson
    Quote Originally Posted by Gordon Levy View Post
    Hi Gordon, I called AFR and they said either gasket would work. The 1250 seemed to align fine with the head intake ports.
    Jan 2020
    State of Jefferson
    A little update on the china wall oil leak... I ended up borescoping under the water neck to see where the gasket sealer was not fully seated across the china wall. There was a tiny 1/16" gap where the oil was coming through. Cleaned the area off with some parts cleaner and ran a new bead under the water neck area. After another test drive it is now leak free. I will probably replace it again this winter when I am not driving the car much but it will get me through the nice fall weather driving rapidly approaching here in Nor Cal.
  4. Likes Railroad liked this post
  5. #44
    Senior Member weendoggy's Avatar
    Aptos, CA
    Quote Originally Posted by Fman View Post
    Great advice, and I also did not let it set up for 1 hr before I set the manifold in place... guess I should have read the directions maybe this has something to do with why it is leaking.
    I am using Permatex Ultra Black, this is what my engine builder recommended. Assuming this is adequate for this task?
    Don't let it set for an hour, just about 5-10min and then install the manifold and torque it down. Then walk away for the day (24hrs) and let it set. You can then recheck the torque and finish buttoning up everything. Also, make sure the surfaces are CLEAN on both block and manifold before putting the silicone down. Permatex UB is good stuff.
    I'm just a victim of a thousand physic wars!
    www.weendoggy.com/cobra.htm
  6. Thanks Fman thanked for this post
  7. #45
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    FWIW - here are the actual application instructions from Permatex for ultra black. Very similar to Ultra Copper that I used as exhaust flange gaskets. They do not recommend any setup time before assembly. Parts should be assembled immediately, but tightened only to the point where it starts to seep out the sides. Then let set for two hours, finger tighten 1/4 to 1/2 turn and let cure for 24 hours.
    https://static.dxengineering.com/glo.../ptx-82180.pdf
  8. Likes Fman, Railroad liked this post
  9. #46
    At one point I did the same. Quite a few squirts of brake cleaner followed by drying w/ compressed air. Then a smear of ultra grey. That worked for over a year until I had a different reason to take off the intake.
  10. Likes Fman liked this post
  11. #47
    Jan 2020
    State of Jefferson
    Quote Originally Posted by JohnK View Post
    Hey thanks John, appreciate the clarification. I will probably tackle this for a winter project. Hope all is well with you and your out enjoying the car!
  12. Thanks JohnK thanked for this post
