Results 1 to 3 of 3
Thread: Moroso 63806 expansion tank and SBF?
    Jul 2024
    I really like the look of these tanks on various builds….I know it’s marketed as a Coyote tank. Would there be any problem using it in a SBF/Windsor build?
    Ottawa Ontario
    This tank from Mike works very well in conjunction with an out of sight recovery tank attached to the back side of the passenger elephant ear.
    https://fortesparts.com/product/aluminum-degas-tank/
    Scott
    FFR #3870 MK II, Spectra Blue/Arctic White, 1974 414W, 10:1, Eagle 4340 crank and rods, KB Pistons, Ported Performer RPM 2.02 heads & intake, QFT SS-650, Comp XR282HR, Quality Roadsters pan, Crane ignition, TKO600, 3.55 gears, 3 link, SA QA1's, Breeze LCA's, Heim joints & VPM F/R bars, Power steering with Hiedts valve, Power brakes, Fortes bump steer kit, 5 bolt axels, SSBC rear brakes, Oil cooler, Pusher fans, Halibrand Cobra III's with Nitto NT555 G2 245/285/17
    Jul 2024
    That looks pretty slick. I’ll call tomorrow and see how long he thinks it’ll be out of stock.
