Hi Gents. Anyone off the top of their head know the torque for the rear CV axle nut? Not listed in build manual.
Thank you.
Thank you.
Hot rod manual says 98 ft-lbs/133 N-m then 45 degrees. Same axle so I can't see why the values would be any different.
Earl
For the IRS, page 275 calls it out as the same.
Curt77,
Here's a quick sidenote. Early in the build, finding specs in the 593 page manual became maddening. I went to an office supply store and got some of those little sticky tabs to mark pages. Any time I'm in the manual and find a critical piece of info, it gets a sticky tab. That's been a huge help with torque settings and with the aluminum chassis panels.
The searchable pdf manual is also a huge help.
Just be aware that it's not unheard of for the manual to have incorrect torque specs. For anything Ford-related (engine, IRS, etc.) I always defer to what Ford recommends, vs. what's in the manual.
I recently had the passenger side half shaft out. On reassembly, I torqued the nut to 98 ft-lb, did the extra 45 degrees, but noticed that the brake disc and brake housing were still slightly loose and actually wobbled. The Nut was not fully clamping everything together. I needed to apply more than another 45 degrees or even 90 degrees more totally to the nut to secure everything. In this process I did the first "extra" 45 degrees and definitely noticed that the looseness/wobble were much diminished. Another 45 degrees eliminated the looseness and wobble. Rotation of the disc seemed OK, not binding, so I left it all at that. So far with a few hundred miles driven everything seems nominal.
