Thread: Coupe Firewall question
    Oct 2022
    Hey-o,
    I see on some builds, an aluminum firewall piece shown below in the photo.
    I can't find this piece and it is not mentioned in the Build Guide
    Is it custom? Is it a good idea?
    Gen 3 Coupe build
    Gen 3 Coyote
    Toronto, Ontario
    Mar 2021
    Ohio
    That is custom.
    X2. Custom piece. Necessary? Probably not. But does clean up the engine bay a little. This was early in my Coupe build and can see how it closes off the area behind the Coyote.
    Edmonton Alberta
    once the body is on you really don't see that area. I also wonder if it will keep more heat in the engine bay? Some people cover the top frame rails around the engine and that looks great.
    David W
    Mkll 4874 built in 2004
    Oct 2022
    Thanks, looks great! What material are you using?
    Oct 2022
    That's something I hadn't thought of. I was thinking maybe it would be cooler for the driver with it, but maybe you are right, it will disperse more heat under the car.
    Mar 2021
    Ohio
    Quote Originally Posted by ChrisNicholls View Post
    0.050 thick aluminum. 2024
