Results 1 to 5 of 5
Thread: Engine Heat
    May 2021
    Engine Heat
    While searching for a brake light issue saw several postings about engine heat.
    When I started up my project for the first time I felt that too much heat was trapped in the engine compartment.
    Discussing my concern with the amount of engine heat with a fellow builder he suggested hood vents from a 1985-1990 Camaro.
    This is a picture of the aluminum louvers (from Summit) and how they look on my build. The air flow is substantial in reducing the heat buildup. They are not period correct but close.
    Hope this may be helpful.
    Cam
  2. Likes DonImbimbo liked this post
    Member KippRacing's Avatar
    May 2023
    Central Iowa
    That looks pretty good!!
    Mar 2023
    Quote Originally Posted by Cam1919 View Post
    Cam
    I am having heat buildup issues as well. I have a Blueprint SBC 383 with a 700R4 transmission. I have added transmission oil cooler and an engine oil cooler mounted under the bed with individual thermostat controlled fans and still running close to 200 with city driving. Do the side louvres provide enough cooling in higher ambient temperatures? What was your source for the louvres?
    Mar 2023
    Cam
    I am having heat buildup issues as well. I have a Blueprint SBC 383 with a 700R4 transmission. I have added transmission oil cooler and an engine oil cooler mounted under the bed with individual thermostat controlled fans and still running close to 200 with city driving. Do the side lovres provide enough cooling in higher ambient temperatures?
    May 2018
    Pinckney, MI
    I created some different side vents for my 383 in the Hot Rod. Temps seem fine to this point ((1300 miles)
    - Peterh226
    35 Hot Rod Truck (Ext) Delivered 11/21/24
    33 Hot Rod Gen 2 #1134 ~1400 miles
    54 Pontiac Star Chief
    05 F-150
