Thanks Thanks:  2
Results 1 to 16 of 16
Thread: Incorrect body alignment or 3/4" tube not welded straight?
    Senior Member Mat1asBEV&ICE's Avatar
    May 2023
    Boston
    Hello.
    Based on the photo below, do I need to re-align the body or is the 3/4" welded at an angle? If it's welded at an angle, I am guessing it doesn't matter?
    I think it's the 3/4" tube (let me know if you want any additional photos) because the body seems to be hitting in the same places on the DS and PS everywhere else. Moving the DS side back is not possible as the body is up against the "horns" (I think that's what people call them) on both sides (where the QJ bolts are). Moving the PS forward (if even possible) would mean a side pipe hole noticeably farther back than the DS.
    Further reason why I think it's the 3/4", the front of the radiator is almost hitting the horn on PS while there's room on the DS. The Breeze lower radiator mount is farther forward on the horn on the PS.
    Thank you for your input!
    Delivery October 2023, #10847, Gen 3, IRS
    They all look like that from what I've been told. If you're OCD, you're going to blow a gasket trying to resolve all the asymmetry that these hand-formed bodies exhibit. Here's a picture of mine -- not as dramatic as your photo shows, but camera angles can make things look better or worse.
    Senior Member JMD's Avatar
    Mar 2024
    Kansas City, MO
    Ha! I just posted about this exact thing a week or so ago. I was concerned something was off as well, turns out that's perfectly normal according to many of the experienced builders who responded to my post about this. Carry on.
    Build thread: https://thefactoryfiveforum.com/show...809#post556809
    MKIV received 5/15/24
    Blueprint 302 tuned by Mike Forte, TKX midshift, IRS, PS, Wilwoods
    Jul 2021
    York, Maine
    Quote Originally Posted by Mat1asBEV&ICE View Post
    Hello.
    I think it's the 3/4" tube (let me know if you want any additional photos) because the body seems to be hitting in the same places on the DS and PS everywhere else. Moving the DS side back is not possible as the body is up against the "horns" (I think that's what people call them) on both sides (where the QJ bolts are). Moving the PS side forward (if even possible) would mean a side pipe hole noticeably farther back than the DS.
    Yep, mine looks exactly the same as yours as do many I've seen.
    Picked up kit 9/6/22. Complete Roadster Kit, IRS, 18" wheels, Forte 302, T5. First build. No auto mechanical experience and beyond excited to learn. Loaded with "Empty Nester" time and energy. Link to my build videos: https://www.youtube.com/channel/UCgX...uCWGcelzGecm1Q
    May 2023
    Boston
    Great to know! I was thinking about getting the Breeze radiator cowl cover. I think this settles it.
    Senior Member FLPBFoot's Avatar
    Cape Coral, FL
    Yes, the Breeze cover makes it look less obvious. Also it closes off that area and forces more air through the radiator rather than letting it flow over the top.
    2nd MK4 #10639 received 3-19-23. Wife's version. Street Snake - IRS, Willwoods, no roll bars, no hood scoop, no stripes, Blue Print EFI 306 with AOD trans, and under car exhaust. Ford Eruption Green with saddle leather interior.
    1st build - Mk4 Roadster #9319, received 4-10-18. IL registration 8/6/19. Moser 8.8. 3 Link. Wilwood brakes. Blue Print 427, Holley 750, TKO 600, 0.64 OD. Paint Dec 2020. Ruby Red with Carbon Flash Black metallic stripes.
    Member Wizbangdoodle's Avatar
    Nov 2023
    As i was installing my radiator, I saw this same thing. I thought my frame was screwed up. I ended up calling FFR and inquiring about it. I was told it is perfectly normal and was that way from the days of using a mustang donor. I guess the mustang radiator needed that angle to fit correctly.
  8. Thanks Mat1asBEV&ICE thanked for this post
    Mar 2013
    Medway, MA
    Sorry but I believe the 3/4" crossbar needs to be cut (from photo looks like the driver side) and re-welded in a level position. I actually discuss this in the installation instructions for the 70558 HD Hinged Upper Mount.
  10. #9
    May 2023
    Boston
    Hey Mark. Just to clarify, the 3/4" crossbar is leveled. It's just that the DS side is farther back. Do I still need to have that crossbar cut and re-welded? I hope not.
  11. #10
    Every Factory Five from Mk1 (actually from before there even were Marks) through Mk4 is like that.
  12. Thanks Mat1asBEV&ICE thanked for this post
  13. #11
    Nov 2023
    Yes, just to clarify, my crossbar is level, but in the horizontal plane, it is not square with the firewall.
  14. #12
    That is exactly correct and, as Greg says, the same for every FFR. The Breeze cover hides it pretty well but more importantly, as PLPBfoot says, it forces air to flow through the radiator vs bypassing it. If you look in through the radiator body opening toward the top of the rad you will see there is a huge area for air to escape.
  15. #13
    May 2023
    Boston
    Thank you everyone for your input. I will order the Breeze cover and "accept" the way it looks.
  16. #14
    Jun 2020
    Rising Sun , Md.
    Jeff said a long time ago, don't look for symmetry in these cars or you'll go crazy. The finished product makes you look past all the imperfections.
    FFR 9883 MKIV ,427 Windsor engine
    TKX 5 speed, Three Link 3.55 gears
    Power Steering, Leather Seats
    18" Wheels and Tires, Drop Trunk
    Fun Package
  17. #15
    Jun 2018
    I cut and re welded mine. Looks much better. Couldn't stand the way the radiator was crooked in the mouth.
  18. #16
    Jul 2021
    Big Canoe, GA
    Yep, mine was as all the others. I did go with Mark R's Mk4 hood hinge and radiator baffle. Amazingly, I did not need to do any mods to the cross bar; the rad cover and hinges went on perfectly. That shiny rad cover was repurposed from our kitchen stove SS backsplash when we went with tile, cut to size and polished. Gotta love home remedies!
    Art Shand, Big Canoe GA
    BPE 347 FI, Hydraulic Tremec TKX, Wilwood front & rear, GAS-N Headers/Touring Pipes, many functional upgrades.
