Results 1 to 11 of 11
Thread: Stupid Question: recommend lug nuts torque
    Senior Member mlewis's Avatar
    Mar 2017
    Groton, Massachusetts
    Hi all,
    Being lazy…
    What the recommended torque on the 18” halibrands rims ?
    Thanks.
    Senior Member lewma's Avatar
    Jan 2018
    San Diego, CA
    90-100 ft lbs ?
    Senior Member Rebostar's Avatar
    Jan 2024
    I was told by the local Les Shwab dealer that for alloy rims use 80 ft lbs. Thats what I've used on all my wheels, never had one come loose.
    I always go 80-90 on the 12-20 lugs that our cars have.
    Yup. Same here. I typically do them in two steps. 50 or so in a star pattern to confirm fully seated and centered. Then 80-90 in a start pattern to finish. Maybe overkill, but always have them that way.
    Senior Member UpNorth's Avatar
    Jan 2018
    Baie Saint-Paul, QC
    85 for me...and they're still on the car!
    80# w/ a torque stick.
    Senior Member MB750's Avatar
    Feb 2022
    Tampa, FL
    Reef on it
    Matt
    My build thread here
    Senior Member Kbl7td's Avatar
    Apr 2022
    Miami
    Until the impact stops turning them
  10. Likes MB750 liked this post
  11. #10
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    Even under the best of circumstances, torque sticks are only marginally accurate. However, you should be aware that with cordless impact drivers torque sticks can be as much as 30% - 50% low, meaning that your 80# torque stick could inadvertently be tightening your lug nuts to 120#. This YT video explains why. I'm not saying that torque sticks should never be used, but IMO they shouldn't be used to achieve the final torque value. I use a 50# torque stick with a cordless impact for the initial tightening, and then follow up with a torque wrench to 85#.
  12. #11
    Jun 2022
    was just thinking this the other day, thanks for asking for me
    MKIV Roadster - Complete Kit - Delivery 10/12/23
