Results 1 to 2 of 2
Thread: fuel tank removal
    Oct 2017
    fuel tank removal
    The in-tank fuel pump went out and I can't get the tank out to replace the pump. Has anyone had to remove their tank and how did you do it. The bars of the frame that come down in front of the tank prevent pulling the tank forward to remove it and you can't pull it backward into the trunk area because of interference with the outlet tubes on the top of the tank and the frame member the runs just above the rear of the tank.
    Sep 2022
    Huntington, IN
    Has to be pushed to one side, for me I pushed it to the driver side and pulled out the passenger side in an angle. It's definitely a wrestling match and you hope you're going to win
