Hi all,
Being lazy…
What the recommended torque on the 18” halibrands rims ?
Thanks.
Hi all,
Being lazy…
Thanks.
Mk4 #9165, Base Kit with lots of options, Delivery on 08/17/2017, Coyote, TKO600, 2015 IRS, 18" Halibrands, 12.99" Wilwoods
90-100 ft lbs ?
Build 2: Gen3 Coupe Complete Kit #309 Ordered 1/25/21, Delivered 6/9/21, CA SB100 Registered 8/27/24 - BluePrint GM 427 LS T56, IRS, AC, Power Steering. Album Here
I was told by the local Les Shwab dealer that for alloy rims use 80 ft lbs. Thats what I've used on all my wheels, never had one come loose.
I always go 80-90 on the 12-20 lugs that our cars have.
85 for me...and they're still on the car!
80# w/ a torque stick.
Reef on it
Matt
My build thread here
Until the impact stops turning them
Even under the best of circumstances, torque sticks are only marginally accurate. However, you should be aware that with cordless impact drivers torque sticks can be as much as 30% - 50% low, meaning that your 80# torque stick could inadvertently be tightening your lug nuts to 120#. This YT video explains why. I'm not saying that torque sticks should never be used, but IMO they shouldn't be used to achieve the final torque value. I use a 50# torque stick with a cordless impact for the initial tightening, and then follow up with a torque wrench to 85#.
was just thinking this the other day, thanks for asking for me
MKIV Roadster - Complete Kit - Delivery 10/12/23
