Likes Likes:  3
Results 1 to 16 of 16
Thread: Anyone using a Quick Jack or similar lift??
    Member maginter's Avatar
    Jun 2024
    Westfield, IN
    Hi All -
    I know this is somewhat off center from the Cobra, but I know people are using lifts to work on their vehicles.
    Is anyone using a Quick Jack or similar device? I would really like a lift and cannot fit a 4 post. New construction garages just are not that big anymore.
    Please let me know if oyu are, how you like it and what you have.
    TIA,
    Mark
    Dec 2021
    Flower Mound TX
    Here you go. https://thefactoryfiveforum.com/show...cks-and-paint)
    I have a set arriving today, like Mark I bought the open box ones and saved some money. https://quickjack.com/5000tl-refurbished/
  3. Likes MB750 liked this post
    Jun 2024
    Westfield, IN
    Thanks! I don't know how I missed this thread....
    May 2020
    I have built several cars ranging from Model A Fords to most recently an A Body Mopar. I love my QuickJack system and look forward to using it for my next project, a FFR roadster.
    Sep 2024
    I have the 7000TLX and plan on using for my build. So far I've just used them to change the wheels on my wife's car. They take a bit of setting up but once you get the hang of them they work very well.
    Woodstock ,Illinois
    Most of the pro builders use them! I have a 5000 rated one and love it! Used on my FFR and daily drivers. It's low enough for me to just drive over with my roadster.
    Senior Member jrcuz's Avatar
    Stafford Virginia
    I used mine to change my oil pan and a friend used them to change oil in his Mk3. Another used them to drop his TKX and change the clutch. I can't remember what I paid for them but I did buy them from Costco for I think a good price.
    JR
    Senior Member lewma's Avatar
    Jan 2018
    San Diego, CA
    I've used them on both my builds. Very useful to get the car in the air but I usually place jack stands then remove the quick-jacks if I need to get under the car as they are bulky.
    Build 2: Gen3 Coupe Complete Kit #309 Ordered 1/25/21, Delivered 6/9/21, CA SB100 Registered 8/27/24 - BluePrint GM 427 LS T56, IRS, AC, Power Steering. Album Here
  10. #9
    Dec 2023
    Eddyville, KY
    I have the 5000 also and I love it.
    Jim
  11. #10
    Yep 5000 from Costco. Recommended!
  12. #11
    Senior Member F500guy's Avatar
    Aug 2022
    Portland, Oregon
    I just ordered a pair, could not find them at Costco online, but used the link for the open box and got some pinch seam blocks as well. Now I have to figure out where I can store them....Free Shipping to boot
    MK IV Delivered June 27, 2023 Build Thread-https://thefactoryfiveforum.com/showthread.php?46069-Lance-s-Roadster-Build-Thread-Starting-the-Al-panel-slog
    "Build a Car" They Said "It Will Be Fun "
  13. #12
    Dec 2021
    Flower Mound TX
    I ordered the open box 5000 per my link and received them yesterday by UPS with free shipping. From what I can tell there didn't seem to be anything open box about the ones I received, it looked like the original packaging and nothing looked to have ever been opened or disturbed. I plan on setting them up today and testing them out.
  14. Likes MB750, BEAR-AvHistory liked this post
  15. #13
    Member BornWestUSA's Avatar
    Jul 2022
    Ventura County, CA
    A note on set up for the quick jacks, I don't know if I read it or saw it on YouTube:
    The provided liquid thread sealer needs to set up for 24 hours before use.
    I did that and it worked great, no leaks.
    Mk4 Roadster #7945, Ford Racing 427W, Quick Fuel 850, TKO600, 3 Link, One of Jeff Miller's last paint jobs. California SB100 completed June 2024
  16. #14
    Oct 2021
    Durham, NC
    Same - we have a one car garage with a door that when open leaves me little room for tall jack posts. Quick Jack has worked quite well!
  17. #15
    Feb 2017
    I have a QJ5000 bought on sale at Costco and one thing to know is that because the frame rails are pretty narrow on the roadster if you have to do any work down the center of the car like install a driveshaft safety loop it is a very tight squeeze between the quick jack. I'm not a big guy and barely squeezed my shoulders flat on my back to do the installation.
  18. #16
    Dec 2021
    Flower Mound TX
    Quote Originally Posted by Nickjj View Post
    True although I found by moving the Quickjacks out as far as possible from the car centerline there's enough room to work. The Quickjacks are about 8-10" wide and you don't have to have the frame tube in the center of them.
