Results 1 to 11 of 11
Thread: Fuel return hose connection question
    Oct 2022
    Hey everyone,
    I have figured out most of my fuel system, but I'm stuck on what is probably an easy answer.
    I'm connecting my rubber 1/4" fuel return line to the fuel pressure regular and also to the in-tank fuel pump (with the hard line in between). The hose is too small to stretch over the fittings.
    I'm sure there is some kind of easy connector that does the job, but nothing in the supplied kit.
    Thoughts?
    Mar 2021
    Ohio
    Quote Originally Posted by ChrisNicholls View Post
    Hey everyone,
    Thoughts?
    Where did the fitting come from? It looks like it uses a quick connect fitting to make the connection.
    Senior Member Kbl7td's Avatar
    Apr 2022
    Miami
    Something like this depending on size.
    https://www.summitracing.com/parts/r...UaAlL4EALw_wcB
  4. Likes PNWTim liked this post
    I personally would not run a 1/4 inch return. 3/8 on both feed and return. All the parts including cloth braided hose can be bought on Amazon or other vendors.
    May 2018
    Chaska, Minnesota
    That return port on the tank is not meant to have a rubber hose slide on it with a hose clamp, it will eventually slide off and cause a major fuel leak and fire hazard, being there are no barbs to retain the hose. That must use a quick release EFI fitting to properly attach that hose.
    Oct 2022
    Thank you!
    Oct 2022
    Thank you! I figured that it needed something like that. Looking into it.
    Oct 2022
    Can you tell me the disadvantage of the 1/4" return? I figured if that what is supplied, then that's probably best
  10. #9
    I have run into a few builds that I could not get the pressure low enough due to trying to push too much fuel through a small hose at idle.
  11. #10
    May 2018
    Chaska, Minnesota
    Summit, Jeg's, or Evil Energy has good selections of those EFI quick release fittings.
  12. #11
    Oct 2022
    Thanks!
