Results 1 to 6 of 6
Thread: Coupe fuse panel placement
    Oct 2022
    Hey,
    I'm just starting my wiring.
    I see a lot of back and forth on the best place for the fuse panel.
    Is there any conclusive agreement on the best placement?
    I'm not against extending some wires, if needs be.
    Senior Member JimStone's Avatar
    Nov 2022
    Niles, MI
    I'm also curious about this.
    I am not a fan of using the angled tube in the drivers footwell for two reasons:
    1) it's visible when opening the driver's door, and hard to make look pretty (maybe some sort of removable cover panel could be made)
    2) That angled bar comes very close to hitting my right knee/shin when seated, so I think I'll cut it out. Otherwise , I think it would drive me crazy constantly bumping into it. I'm sure this depends on my seat choice and personal body makeup/anatomy
    But the passengers side footwell is taken up by the AC unit, so not sure there's another place for it
    Ordered: 2/14/2024
    Received: 5/24/2024
    Member PNWTim's Avatar
    Aug 2024
    Damascus OR USA
    In post #97 of edwardB's build @Mike Everson was advocating placement in the dash area. FWIW, Paul stuck with the "above the left knee" location which seemed to work out OK for him.
    Coupe complete kit ordered: 9/26/24. Gen 4 Coyote. T-56. IRS w/3.73. Wilwoods. PS. HVAC. Side windows.
    Mar 2021
    Ohio
    I opted for one of these, which others have used, since I need to add some more fuses, relays, and some heavier guage wires. You could also mount this out under the hood, since it is a sealed enclosure. It is a lot of work to switch it out and to understand FFRs wiring schematics. Overall the cost is not bad, plus you can use the same terminals and crimper to make water tight connectors for harness connections.
    Regarding the placement of the fuse panel on the angled brace in the driver's side footbox:
    - It's barely visible when the car is on the ground. You don't realize how low these are until they're done and sitting on the ground. Very different sight lines than when it's on jack stands or whatever during the build. I sure wouldn't move it for this reason alone.
    - There's no issue with the fuse panel (or the bar itself) hitting your knees or whatever. Including climbing in/out and while driving. Granted, I'm average height (5'9") and "average weight" (I'm sticking to that...). If you're taller, you're going to need you seats further back and likely lower than mine. So I would expect a similar outcome.
    - I would not recommend cutting pieces out of the frame. This frame is computer designed and all the pieces are there for a reason.
    - While the Ron Francis harness is more optimized for the Roadster than the Coupe, if you move it you're asking for even more work than you already have. I modified mine a lot (check my build thread) but it would have been even worse had I placed it somewhere else. Plus with all the junk I stuffed under the dash, moving it wasn't an option anyway.
    FWIW
    Senior Member Kbl7td's Avatar
    Apr 2022
    Miami
    Mine is all custom but chose center of the car on the angled bell housing cover. Out of sight, as long as you’ve done your wiring right you should rarely need to access the fuses.
