Thread: Is this how these small panels mount? (Side of footbox)
    Senior Member MB750's Avatar
    Feb 2022
    Tampa, FL
    Numbered 4 and 8. I took them off a really long time ago and the drawing they give is garbage.
    Thanks in advance.
    Matt
    My build thread here
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    I took a bunch of photos of the sheetmetal as it came from FFR before I disassembled everything. This is how those pieces were put together from the factory.
    Feb 2022
    Tampa, FL
    Thanks for this. From the looks of your picture those two pieces slide thru the slot in #3, rather than mount them to the outside surface of #3.
    I need to go buy rivets, I'll fiddle with it when I get back. Fortunately the only holes drilled so far were the screw holes from FFR (and one from me).
    Matt
    Inside or outside. If you mount them outside you'll gain .080" more foot room
  5. Thanks MB750 thanked for this post
    Feb 2022
    Tampa, FL
    Thanks Jeff. I was hoping that was the case. Much easier to install they way I've got them now.
    Why the manual doesn't say to install those things BEFORE you put on #3 is beyond me...
    Matt
    Jul 2021
    Tonganoxie, KS
    Quote Originally Posted by MB750 View Post
    I noticed that was going to be a challenge if the outside footbox wall was riveted in place first, so I riveted all those little bits to the outside wall before installing the outside wall.
    Build Thread Here Partners: Levy Racing, Summit Racing, LMR, Breeze, Forte's Parts, Speedhut, Amazon
  8. Likes MB750 liked this post
  9. #7
    Feb 2022
    Tampa, FL
    I've got around a 50/50 chance of success when I blaze my own trail trying to interpret something from the manual so I figured I should just ask first. I'm tired of drilling out rivets because I interpreted something wrong. Y'all are a great resource, and I can wait a day to finish something if I only have to do it once.
    Matt
