Results 1 to 6 of 6
Thread: Fuse box on passenger side
    Jun 2021
    Sudbury, MA
    Hi there -
    I'm at wiring stage and have been staring at the mess of wires and reading posts here to come up with a plan. I read a post from Feb 2024 on moving the fuse box to the passenger side. Looks like GoDadGo and then ryanstory went this route. For you guys and others that have done this, I was looking for any additional advice on making the move.
    It appears I'll need to:
    1) make a bracket to hold the fuse panel under the dash (or use a dash filler plate and cut a hole in it).
    2) move the horns to the passenger side in the engine bay
    3) rewire the turn signals to swap left/right
    4) extend the wires for the brake and clutch safety switches to the pedal box
    5) other...?
    I haven't looked ahead in the manual, but there is a space to the right of the firewall, and I'd like to run the front harness there (picture below). Any issues with this? I do not have a heater, wipers or glovebox.
    I'm resisting the urge to diet the wiring harness so I can get on the road sooner than later...but we'll see.
    Thanks, Joel
    Ordered Aug 2023; Delivery Dec 2023.
    MK IV Complete Kit w/ IRS, Forte SBF 427W w/Edelbrock ProFlo 4, TKX, Wilwood 12.88, Willwood EPB.
    Power steering, manual clutch
    Dec 2023
    Eddyville, KY
    The guys at the school house mount it on the drivers side but they mount it with a piano hinge at one end and a single screw at the other, undo the screw and it all swings down making it easy to get to. That might be a less complicated option.
    Jim
  3. Likes BEAR-AvHistory liked this post
    Sep 2015
    Hamersville, Ohio
    I put my fusebox on the passenger side of the dashboard with a cover over top. When the cover is removed, everything is visible through the windshield. No need to stand on your head to access!
    Kit #361, arrived 10/2015, still in progress
    818C highly modified, corvette suspension
    Estimated completion summer 2023!
    1989 turbo Supra 5 sp
    2017 Tundra
    Senior Member Rdone585's Avatar
    Jul 2020
    Near Milwaukee, WI
    Just realize that every choice you make for the location of things limit your choices down the road for other items (e.g. heater, AC, mounting for fuel pressure regulator, mounting for mechanical throttle assembly). My ignition module (for others the ECU) is mounted on the passenger side, along with some of the wiring. I guess my point is, make a plan for everything now and what you might do in the future or you could find your options limited. Make sure your plan includes maintenance accessibility. It's never perfect, but the more planning up front, the less headaches down the road.
    MkII: 408 Dart block dry sump, 750cfm carb, G-Force T-5, 8.8 rear with 3.55 gears, 3-link, Kirkey seats, black ceramic coated twister mufflers with shields and adjustable turn down tips, passenger roll bar, front and rear roll bars. 2020 GT500 Magnetic metallic, with white and lime green stripes.
    I've been street legal for a few years and moving the fuse block over has kept it high and dry.
    https://thefactoryfiveforum.com/albu...chmentid=51762
    Living in Southeastern Louisiana puts us in the rain drops very often.
    Feb 2022
    Flower Mound, TX
    I put mine in the trunk, so obviously it's not the RF harness, and thus this post is probably no use to you.
