Results 1 to 3 of 3
Thread: Hatch Area Rear Wall fitting
    Oct 2021
    Quick question on the hatch area rear wall - in the manual it is riveted in place after the body is installed, however, I would like to still have access to the rear of the car once it is completed and thus want to make the rear wall removable.
    My plan is to use rivnuts to the frame, a couple on the side walls and then at the top for fastening the body to the wall.
    Am i correct in assuming, that the rear wall is in the same position for all the builds, since it is fastened to the side walls which are fixed in place? And that i can drill and rivnut rear wall without having the body on?
    Any better ideas on how to make the rear wall removable?
    Nick
    Senior Member Kbl7td's Avatar
    Apr 2022
    Miami
    Rivnuts on base for me. Then two more on either side of the hatch latch. The weatherstrip on top of that aluminum piece keeps it pretty well in place.
    Oct 2021
    Thanks!
    Did you not use any fasteners at the top of the rear wall to fasten the body to it?
