Results 1 to 3 of 3
Thread: Type 65 Daytona Coupe, complete kit, crate 302 - what electronic fuel pump?
    Jan 2024
    Can you guys help identify an electronic fuel pump appropriate for a crate 302 with a single Holley 4 barrel. I have the new Mustang gas tank that comes with the complete kit, picked up this past April.
    Bob G.
    Colorado Springs
    You're not needing anything fancy or high performance for that engine. Get a stock Mustang in-tank pump. It will supply all the fuel you need, be inexpensive, readily available, and last forever. What more can you ask for?
    Contrary to popular belief, the fuel pump does not control pressure. That's what the pressure regulator does. Get a quality bypass type regulator and mount it close to the carb. A return line helps prevent vapor lock.
    .boB "Iron Man"
    NASA Rocky Mountain, TTU #42, HPDE Instructor - Retired 10/24
    www.RacingTheExocet.com
    Jan 2024
