Hi,
I could use a little help. Running through all my sheet metal for another powder coat run and I have found a panel I can’t figure out. It has a 3-4 and a 1-2 stamped in it. Picture attached. Anyone know what it is?IMG_1874.jpg
Hi,
It's the pattern to drill the steering shaft on the carbon dash.
OH! Thank you mike!
I didn't find it very accurate. Seemed to be about a 1/2" off to the passenger side, but mileage might vary.
That is the panel for your steering shaft placement, gauge placement. MK1, MK2, MK3, MK4. I'm sure you have the MK4. Just make sure it's been corrected for steering shaft placement. I received mine and it was incorrect, FFR was to fix the issue.
