Thanks Thanks:  3
Results 1 to 5 of 5
Thread: What is this panel?
    Senior Member danmas's Avatar
    Jan 2019
    Mead Colorado
    What is this panel?
    Hi,
    I could use a little help. Running through all my sheet metal for another powder coat run and I have found a panel I can’t figure out. It has a 3-4 and a 1-2 stamped in it. Picture attached. Anyone know what it is?IMG_1874.jpg
    Mk4 complete kit arrived 10 May 23
    Current BOM
    It's the pattern to drill the steering shaft on the carbon dash.
  3. Thanks danmas thanked for this post
    Likes danmas liked this post
    Jan 2019
    Mead Colorado
    OH! Thank you mike!
    Current BOM
    cv2065's Avatar
    Dec 2017
    I didn't find it very accurate. Seemed to be about a 1/2" off to the passenger side, but mileage might vary.
  6. Thanks danmas thanked for this post
  7. #5
    Sep 2024
    That is the panel for your steering shaft placement, gauge placement. MK1, MK2, MK3, MK4. I'm sure you have the MK4. Just make sure it's been corrected for steering shaft placement. I received mine and it was incorrect, FFR was to fix the issue.
  8. Thanks danmas thanked for this post
