Thread: Window Tint for rear hatch
    Oct 2020
    Im close to permanently mounting the rear hatch glass and thought it would be much easier to apply the tint prior to mounting. I called a local place and was given a price of $400 for 35% standard tint or close to $500 if I prefered ceramic tint. It seems extremely high and considering attempting it myself with the risk of it not working due to multiple curves. Any thoughts on a particular brand?
    Brandon
    Senior Member JimStone's Avatar
    Nov 2022
    Niles, MI
    I'd be interested as well
    Erik Treves has a guy that looks to do awesome work with the Coupe hatch. Have heard it's quite difficult.
    I didn't ask what it cost though
    Gen 3 Coupe #576 - "Project Deimos"
    Ordered: 2/14/2024
    Received: 5/24/2024
    Build Thread: https://thefactoryfiveforum.com/show...upe-has-landed!
    Mar 2020
    Couple years ago I paid $250 for a 32% tint. Got it done prior to final assembly which was much easier.
    Oct 2020
    I just ordered a 40 in X 10 Ft roll from Northern Tint which is ceramic 35% for $65 free shipping. I did watch a couple videos on installing compound lines and using a heat gun is necessary to shrink the tint. Im going to give it a try and see how it goes for that amount of savings.If it goes well I will have enough left over Ill be happy to give the remainder to one of you guys if anyone wants it.
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    I had a quote of $600 on mine. Needless to say it didn't happen. I would be interested in your leftover material.
    Scott Pregont
    My Albums
    Senior Member dstelter's Avatar
    Jan 2019
    Paige TX
    Yep had mine done early as well. before the build was complete. don't remember the cost (not cheap) but i did try it myself the first time and it was terrible. Had to search to find a local guy with a wide enough roll so it would not have a seam in it. been one summer with it and driving my Coupe. cant image not having it. it still heats up and you can feel it, especially when the sun is coming in from behind. still thinking of some sort of clear panel or a sheet of clear flexible plastic that can easily be mounted and dismounted to the roll bar. That would give the AC a better fitting chance to cool the drivers area. Doug
    Indy Shu's Avatar
    Indianapolis, IN
    I had mine done for $275. mid grade, ceramic, 20%. The glass still gets very hot and can radiate heat but the surfaces inside the car are only warm to the touch.
    Gen 3 Coupe #334 received 11/4/21. Coyote, IRS, TKX, Wilwoods
    '02 GT donor, 4.6 sohc, Received #5488 on 5/29/06. 3-link, ps, pb. Hoosier Cobra member (Hoosiercobra.com)
