Post Thanks / Like - 0 Thanks, 4 Likes
George T
Type 65 Coupe #338, Picked Up 4-Aug-07, Roller on 8-Mar-09, 1st start 8-Sep-13, 1st Autocross 7-Oct-18, finished sanding & sprayed paint myself 6-Nov-21, IRS/LCA/Koni/traditional gages/Kirkey/pin-drive rear width/15" Torq-Thrust Ds/44IDFs/Brodix ST5.0R heads/Eagle internal-balance crankshaft/oil pan by Armando/home-made turkey pan/S-10 mid-shift T5
The car looks awesome and fits right in with the other supercars Okay maybe not but way cooler! Paint job looks great and that close to the color scheme I wanted
but got a partially built Coupe already painted. What do you have in place of the side vents behind your side windows? It looks really good and Im close to installing windows.
Oh and by the way the helmet is definitely cool and would recommend a matching racing jersey!
Nice helmets guys and tribute to Bob!
Brandonk603
Brandon603,
The Rear-Quarter AND Door Windows have been subtly, but at the same time significantly custom modified on my coupe. The customizations were all a part of my "Replimod-GT" build of my Coupe.
I've posted in this forum a few of the more significant custom mods and their actual design and build processes.
Regarding the Rear-Quarter window, the shape has been changed and there's a shaped piece of gray-tinted clear Lexan in place. The Lexan-Pane is removable with maybe a half hours' worth of work on each side and could be replaced with a scoop version or some other styled version (Viper-like for instance).
Anyway, here's the link to my FFR Forum "D8YTONA Custom Features Explained" post that explains and shows much of the Side Windows Custom Mod.
(Warning: extensive, not for the faint of heart):
https://thefactoryfiveforum.com/show...ures-Explained
For insights into some additional significant mods on my coupe here the links to are similar Features Explained link in the FFR Forum:
https://thefactoryfiveforum.com/show...t-4-Hood-Vents
https://thefactoryfiveforum.com/show...d-Nose-Corners
https://thefactoryfiveforum.com/show...amp-Taillights
