Thanks Thanks:  3
Thread: MS3Pro Mini and Infinitybox 20 Circuit Harness
    I’ve purchased a MS3 Pro Mini ECU for my project. The engine is a 2007 JDM Forester 2.5 Liter Turbo SG-9. Also using a 5 speed transmission. Does anyone know where I might find the pin diagram for the main connector on the oem engine harness.
    Feb 2019
    Houston, TX
    Did you try nasioc.com? I only have a 2006 Pin-out which might not work.
  3. Thanks hronald395 thanked for this post
    May 2020
    Your best bet is to try and find the Factory Service Manual (FSM) for that car or engine. You can find the USDM FSMs online but the JDM one might be a little more challenging. The NASIOC or wrx/sti forums is a good idea too.
  5. Thanks hronald395 thanked for this post
  6. #4
    Quote Originally Posted by hronald395 View Post
    These are the schematics for a US 04 & 05 forester xt. Could you check the pin numbers and color code to see if it matches your engine?
    https://1drv.ms/b/c/b1afde2c10c76e07...lLfjA?e=gtaq2g
  7. Thanks hronald395 thanked for this post
  8. #5
    I’ll check it out.
  9. #6
    Am trying NASIOC and Alldata.com.
