Results 1 to 2 of 2
Thread: 818 2.0 engine, 5-speed and rear suspension available
    Mar 2021
    SE WI Kettle Moraine
    My kit is a 2014 818s that has not been finished. I am replacing the Subaru drive with Acura J-3.2 V6.
    The 2002 Subaru engine is complete, the previous owner upgraded the timing and water pump. The package includes turbo, downpipe and intercooler. ($250)
    Radiator and fans also available. ($40)
    The 2002 five speed transaxle was upgraded to RWD by the previous owner. ($250)
    The rear suspension less coil overs is available. The (10) links are the FI/Cusco upgrade. ($300)
    I can upgrade the lower trailing arms to the VCP relief for ($60)
    Knuckles and axles are available.
    I also have an MR2 shifter and FFR shift cables.
    17/18in FFR wheels and tires will be available.
    jim
    Pictures do not load.
    Mar 2021
    17/18in FFR wheels and tires are available.
    jim
    The Acura wheel lug pattern is 5 X 114.3 and I will be upgrading the front uprights/hubs so the 5 X 100 originals are also available.
    Some of my Wilwood brake bits will be available.
    I have the chassis stripped and will remove the entire frame aft of the rear hoop. That could be used as a crash repair part.
    Prices negociable
    Pictures still do not load here.
    pdxillc@gmail for pictures.
    jim
