I`m moving up north and no time to enjoy at this moment in life.
If you want to expedite the process of owning a modern MKIV, all you need is to drive as is until is time to paint!
Here is my build thread:
Specs / parts that are part of the sale.
FFR MK-IV kit:
Powder coated chassis
Coyote Mounts
Stainless steel exhaust - ceramic coated
Independent suspension
Coil over Koni shocks
Cut-out fiberglass
All other hardware
Coyote Gen 3 engine
6 speed MT82 transmission
Mustang Cobra Torsen rear differential
Engine management - FuelTech FT550 + 2 Nano + Sparkpro - Dyno tuned with 470HP @ the wheels
Ford performance 60lb/hr injectors
Several parts for tuning the Gen3
Power steering from KRC
Wilwood front brakes
Wilwood pedal
Rear brake manual valve
Electric E-brake
Optima (yellow) battery w/ Breeze battery support on engine bay
Hi amp alternator from Mechman
Formacar MT82 adapter for shifter
Tailored driveshaft
Konig Wheels (Matt black R18 10.5 rear, R18 9.5 front)Nitto NT-101 tires (275/35ZR18 front, 315/30ZR18 rear)
Carbon fiber dash with glove box
Full set of Speedhut gauges
Full set of billet aluminum buttons (including on the transmission tunnel cover) and warning lights
All electrical components in conduits and connected with waterproof Deutsch connectors
New gas tank
Breeze trunk extension
Breeze seat support
Breeze Radiator shroud
Breeze Trunk cubby
Breeze KoolMat kit (not yet installed)
Heated seats hardware
Carbon fiber Ford Mustang gear shifter
Ford performance racing steering wheel with quick connect
And much more that I`m probably forgetting to list.
As you can see in the picture or the build thread, my idea was to create a more modern look (all black, no chrome) with a dark color (dark blue) body, but at this stage it is up for the new owner to decide.
Quick math showed me that I spend (hopefully my wife does not see this) more than $65K on parts alone, including the kit.
Asking $64K.
Has 30 Miles of testing on it only
The car is licensed in NC as a 1965 vehicle - all taxes paid
I`m in North Carolina in Chapel Hill. (2 hrs from Charlotte or 30 min from Raleigh)
Please email / text for any inquires and hi def pics
(919)-525 4826 - [email protected]
