London Cobra Show
Thanks Thanks:  5
Likes Likes:  2
Thread: Summit SUM-300103-16 (56 Ounce) Tank?
    Jul 2024
    BC, Canada
    I have seen in past post some say the have used this tank. Can Anyone weigh in or have pictures?
    I like that it is SS so will be polished longer than the FFR one. Its larger volume wise than the FFR one and it still looks very similar while taking up a similar volume to the FFR.
    https://www.summitracing.com/parts/sum-300103-16
    Yes the Moroso, Canton, etc. are very nice pieces however don't seem to quite hit the mark on the above points quite as well.
    I’ve used it on at least 2 cars. No complaints.
  3. Thanks Doc76 thanked for this post
    Likes Doc76 liked this post
    Copperhill, TN
    Looks like the one I used on my car when the FFR one proved to be too small. Works great.
  5. Thanks Doc76 thanked for this post
  6. #4
    Senior Member FLPBFoot's Avatar
    Cape Coral, FL
    Same one I used with my 427. 5 years and 6,000+ miles and looks bright shiny and new. Go for it!
    2nd MK4 #10639 received 3-19-23. Wife's version. Street Snake - IRS, Willwoods, no roll bars, no hood scoop, no stripes, Blue Print EFI 306 with AOD trans, and under car exhaust. Ford Eruption Green with saddle leather interior.
    1st build - Mk4 Roadster #9319, received 4-10-18. IL registration 8/6/19. Moser 8.8. 3 Link. Wilwood brakes. Blue Print 427, Holley 750, TKO 600, 0.64 OD. Paint Dec 2020. Ruby Red with Carbon Flash Black metallic stripes.
  7. Thanks Doc76 thanked for this post
  8. #5
    This is a recent picture of the Summit tank that is about 10 years old. Still shiny with no special attention to it over the years. Its no longer in use as I went with a closed system a number of years ago using a Moroso tank to better evacuate air from the left cylinder head. Its a Coyote thing you can see the small hose in the picture. Never bothered to take the Summit tank out.
    Kevin
    MKIV #8234
  9. Thanks Doc76 thanked for this post
  10. #6
    Jul 2024
    BC, Canada
    Has anyone ran this one?
    I’m unable to use the titled tank as planned.
    Canton Racing Coolant Recovery/Overflow Catch/Fill Tanks 80-201R (it’s the round 2.5qt)
    https://www.summitracing.com/parts/ctr-80-201r
  11. #7
    Feb 2022
    Flower Mound, TX
    You can't go wrong with Canton. I have two in my cooling system, but not that one. Canton operates an ebay store with open box and blemished product. You may be able to save some money.
  12. Thanks Doc76 thanked for this post
