Likes Likes:  2
Thread: Daytona coupe Reverse Lights Question
    Aug 2017
    Hi Everyone!! So i wired up my reverse lights on my Tremec TKO 500.
    I bought the pig tail off of Amazon. Wires coming out is the same color so i am assuming that it doesn't matter installation on the two male ends. Meaning either or can be positive.
    Below is a picture of how i wired it up.
    So yes, its not working.
    I put it in reverse, power up the car. Not running, just powered up and the reverse lights not running.
    from my drawing, what did i miss. I am assuming that the speedometer lead is the source of the power to the transmission.
    Senior Member Kbl7td's Avatar
    Apr 2022
    Miami
    Typically the reverse switch is a simple switch, that’s it. Either you use it to interrupt the 12v to the lights. Or use it to interrupt the ground. For simplicity ground the reverse lights near the lights at the frame. Run a 12v always on source to the switch, then from the switch to the 12v power to the lights.
    From the picture you posted it appear you ran the ground to one leg of the switch, then the 12v from the top there leg to the lights.
    If you need an easier way to think of it, picture a led light next to a 9v battery, pos to pos neg to neg, it’ll always be on. Put the reverse switch in between either the ground side or the pos side and now you have the ability to turn it off.
    Aug 2017
    Quote Originally Posted by Kbl7td View Post
    Are the legs on the tremec reversable? or are they specific to negitive and positive?
    Senior Member UpNorth's Avatar
    Jan 2018
    Baie Saint-Paul, QC
    Have you tried first to connect directly your reverse lights to the battery just to confirm they light up when under current?
    Aug 2017
    No i havnt yet. i will now
    Falmouth, MA
    You have two leads to the switch, one should go to a hot or positive location that comes on with the ignition, the other lead would go to the backup lights. When shifted into reverse the switch will complete the circuit and the lights should come on.
    Quote Originally Posted by Automan View Post
    ...I am assuming that the speedometer lead is the source of the power to the transmission.
    No. To confirm what others have said, you have to supply the +12 volts. The reverse switch in the transmission is just a simple OFF-ON switch, not connected to anything else in the transmission. Choose a +12V source that's on with the ignition. On my Coupe build, I used the radio circuit (no radio in the build) and shared the backup lights with the American Powertrain reverse lockup module. Both relatively low draw, especially the lights if they're LED's. Route to one side of the switch. The other side to the lights. Then ground the lights. When the ignition on, and the transmission is in reverse, the switch will close and the lights go on. Have done this on a couple builds. Pretty straightforward.
  8. Likes PNWTim liked this post
    Aug 2017
    Thankyou everyone for your help in this. I have Reverse lights working now when required!!!
  10. Likes PNWTim liked this post
