Results 1 to 22 of 22
Thread: Help Identifying This Spring
    Jul 2021
    Tonganoxie, KS
    I found this little guy sitting on the driver's upper floor, below the steering shaft. I have been working on wiring, and I removed my dash (temporarily installed) to work on the wiring behind the dash. I think this spring showed up after I removed my dash. I can't find anything in the dash that this might go to.
    Greg
    Build Thread Here Partners: Levy Racing, Summit Racing, LMR, Breeze, Forte's Parts, Speedhut, Amazon
    Norton, MA USA earth
    Looks similar to the one in the Russ Thompson turn signal.
    Jul 2021
    Tonganoxie, KS
    Sadly, I don't have Russ's turn signal. I'm just using the kit-supplied toggle.
    Jan 2012
    Central OK
    My headlight switch has a sprung button you press to release the shaft. Could it be from a headlight switch?
    -Kyle
    Jul 2021
    Tonganoxie, KS
    Quote Originally Posted by kgkeys View Post
    -Kyle
    That's a good guess. I just checked mine, and my sprung button is still intact. The headlight switch spring is about the same size as the little guy in question, but the unidentified spring is stiffer.
    Greg
    Senior Member Norm B's Avatar
    Brake light or clutch safety start switch?
    Norm
    Jul 2021
    Tonganoxie, KS
    Norm
    Another great guess, but both seem to be intact.
    Jun 2023
    Texas Hill Country
    BUDFIVE
    Complete kit order 8/28/2023
    347 Ford Dyno 10/12/2023
    Kit Delivery 11/28/2023
    First Start 7/4/2024
    Go Cart 8/31/2024
    Jul 2021
    Tonganoxie, KS
    I didn't, but wondering if this spring is off of a tool I'm using. I don't recall any spring-loaded tools. Hummm...
    Oct 2019
    Erin, Ontario CANADA
    Horn button?
    Senior Member Rdone585's Avatar
    Jul 2020
    Near Milwaukee, WI
    From a broken cleco? Or perhaps from one of your quick clamps?
    MkII: 408 Dart block dry sump, 750cfm carb, G-Force T-5, 8.8 rear with 3.55 gears, 3-link, Kirkey seats, black ceramic coated twister mufflers with shields and adjustable turn down tips, passenger roll bar, front and rear roll bars. 2020 GT500 Magnetic metallic, with white and lime green stripes.
    On a roll Al_C's Avatar
    Wheaton, IL
    Well, it certainly didn't come from the spark plug... Seriously, I looked at my dash, and I can't see anything that would have that kind of spring
    Jul 2021
    Tonganoxie, KS
    Quote Originally Posted by Rdone585 View Post
    I thought about a cleco, but I've looked all of mine, and they're all intact. I'm at a loss.
    Jul 2021
    Tonganoxie, KS
    Quote Originally Posted by narly1 View Post
    Horn button?
    Horn button is good.
    RJD's Avatar
    Northern Virginia
    Are you missing a coil over?
    Indy Shu's Avatar
    Indianapolis, IN
    Do you have an NRG quick release hub? There’s a spring in there but I can’t remember how big. ��
    Gen 3 Coupe #334 received 11/4/21. Coyote, IRS, TKX, Wilwoods
    '02 GT donor, 4.6 sohc, Received #5488 on 5/29/06. 3-link, ps, pb. Hoosier Cobra member (Hoosiercobra.com)
    Jul 2021
    Tonganoxie, KS
    Quote Originally Posted by Indy Shu View Post
    I don't.
    Member MaxVmo's Avatar
    May 2023
    Have you disassembled a Colt 1911 recently? Still looking for that spring….
    Set it aside where it won't get lost and move on. Eventually it's use will show up.
    Senior Member Bill Elliott's Avatar
    Jan 2023
    Woodway, TX
    My wire strippers have a spring like that.
    Delivery Date 6-24-23 Build thread Living the Dream
    SBF 427 564hp/576tq Holley Sniper with Hyperspark by Smeding Performance. Tremec TKX .68 OD. IRS . Wilwood 12.88 brakes. Wilwood EPB. First start 11-17-23. First go cart 11-20-23.
    Jul 2021
    Tonganoxie, KS
    Yep, that's what I've settled on.
    Greg
    Jun 2020
    Rising Sun , Md.
    That is a spark plug coilator spring. It provides the spring energy for the electricity to jump the gap in the plug.
    FFR 9883 MKIV ,427 Windsor engine
    TKX 5 speed, Three Link 3.55 gears
    Power Steering, Leather Seats
    18" Wheels and Tires, Drop Trunk
    Fun Package
