Results 1 to 10 of 10
Thread: My TKX seems too low and my driveshaft angles up?
    Jul 2024
    2022 MK4 IRS with SBF: my driveshaft has a pronounced angle up after the forward u-joint. Also, my shifter stub seems a bit low. If I lay a strait edge across the tunnel, it bisects the two shifter holes exactly. Is this height correct or did I miss something? Thx
    Most have to shim the trans mount, usually 1/2 to 3/4".
    This should raise everything to work.
    I loosen the motor mounts to do this.
    Jul 2021
    Tonganoxie, KS
    I just installed my TKX and 427W a few weekends ago. I also have IRS. I bolted on three of Forte's shims right out of the gate, since that seems to be what most folks do. Mine seems to have no crazy angles. I haven't measured my angles, but probably won't, as it looks pretty good as-is.
    Greg
    Build Thread Here Partners: Summit Racing, LMR, Breeze, Forte's Parts, Speedhut, Amazon
    Jun 2023
    Panama City, FL
    I, too, have a MkIV with TKX, IRS, and SBF 302 that I recently installed. I'm with gbranham/Greg. I went ahead and used 3 Forte shims during initial install and everything lined up near perfectly. I still haven't go-carted, so I can't give any input on running or vibration yet. I don't expect any issues, though.
    Jason
    Jul 2024
    No mention of this in the manual eh?
    Jul 2021
    Tonganoxie, KS
    Quote Originally Posted by Windsorpower View Post
    The manual is a guide at best. This forum is your true installation manual.
    Jul 2024
    Oh I get that, I’ve got hundreds of hours here, but missed the need to shim the gearbox.
    That’s because it’s not universal and will vary depending on engine, transmission and rear suspension.
    Jul 2021
    Tonganoxie, KS
    On both of my builds, I realized shortly after assembling all the suspension bits that I was no longer using the manual. So much of the build after that point is unique to each car; I didn't find much value in the manual at that point. And even for assembling the suspension, I mostly used it as reference to ensure I was using the right bolt in the right spot.
    Greg
    Just to do a quick check find anything including a piece of plywood that you can make into a 3/4" spacer. Pull up on the trans and slip it under. You don't even need to bolt it as it is just an eyeball check to see if things look better.
