Results 1 to 5 of 5
Thread: Expansion tank mounting
    Senior Member BRRT's Avatar
    Sep 2020
    Hey guys, how far above the 3/4" upper radiator mount tube can an expansion tank be mounted without interfering with the hood?
    For example, in this picture (Thanks Kevin!), how far above the 3/4" tube to the top of his radiator cap?
    Thanks for the info!
    Roadster delivered 8/27/23
    Chevrolet Performance LS3
    Might be hard to see but the rivet in the box holds one of the mounting straps to the tank. Its bent even with the bottom of the cross brace. From that bracket at the bend to the top of the cap is just under 4"
    Kevin
    MKIV #8234
    Sep 2020
    If I am understanding correctly, from the bottom of the 3/4" tube to the top of your radiator cap is just under 4", correct?
    Quote Originally Posted by BRRT View Post
    Yes. The side of the tank is 2". From the top of the tank to the top of the cap is less than 2 inches. The bottom of the tank is even with the bottom of the bar.
    Kevin
    MKIV #8234
    Sep 2020
    Thanks so much! Exactly what I needed!
  6. Thanks BEAR-AvHistory thanked for this post
