Thread: Side marker/meatball/roundel light wiring
    Louisville, KY
    I'm just about finished up with my wiring and nearly forgot about side lights for the meatballs. How did you guys wire these side lights up? Do they come on with the headlights, or on a separate switch?
    2nd 289 Build In progress. 302, midshift T5, IRS, 15" Halibrands
    Senior Member Jphoenix's Avatar
    Apr 2020
    Bonney Lake, WA
    My 289 kit did not include the meatball lights - did you buy them separately? If I had them, I'd wire them to the marker light circuit.
    Jim Phoenix
    Coupe-R delivered 8/10/2024
    289 USRRC, F5R1011063RD - delivered same day
    Coupe-R has a Ford Performance 363 mated to a TKX, 18084.
    Many details on my Coupe-R are different from a typical Coupe build because mine is not street legal, race only.
    289 has a BP 302 mated to a TKX 18084.
    "For a little more, you can do it yourself." - Ed Hollingsworth... 6-Pack forums
    Louisville, KY
    Quote Originally Posted by Jphoenix View Post
    I purchased the lights separately. https://www.csxparts.com/p-1330-ligh...ber-light.aspx
  4. Thanks Jphoenix thanked for this post
    Sep 2015
    Beachside
    I wired mine into the headlight switch. Routing through the door wasn't too bad. I used black sheathing for the wires and a rubber grommet on the door to clean up the installation.
    FFR #8833 289 FIA 3-link
  6. Likes BlueMud liked this post
  7. #5
    Louisville, KY
    Quote Originally Posted by cnutting View Post
    Perfect, thanks! How did you wire it into the switch?
  8. #6
    Sep 2015
    Beachside
    I spliced it into the wiring harness. Did a lot of surgery on that, also spliced in a floor mount high beam switch.
