Results 1 to 3 of 3
Thread: Has anyone done an air suspension?
    Apr 2024
    Looking at adding Ridetech Shockwave setup. Wondering if anyone has seen/done it. I'm going to see if there's enough room under the bed, otherwise mount it in a toolbox in the bed.
    https://ridetech.com/product/ridepro...-4-way-system/
    https://ridetech.com/product/univers...e-7000-series/
    Senior Member mkassab's Avatar
    Johnson City, TN
    I added air bags to my rear end suspension..... but not what you're referring to. I documented in my build thread, link in signature below.
    Mark
    Mark
    '35 Truck
    Build Thread: https://thefactoryfiveforum.com/show...35-Truck-Build
    Brevard, NC
    Senior Member Pat Landymore's Avatar
    Dec 2018
    SW Calgary, AB
    I believe this fellow did air suspension about 4 years ago…
    Check out this posts….he did a lot !!! of modifications to the original FFR kit. Very interesting stuff.
    https://thefactoryfiveforum.com/memb...ord-Hoonatruck
    Best Regards,
    Pat
    Once again with an 88 mm Turbo, Big Block Chevy powered, ‘35 Hot Rod Pickup
