Thanks Thanks:  30
Likes Likes:  115
Page 6 of 6 FirstFirst ... 456
Results 201 to 218 of 218
Thread: Angelina: Build Story of my 4-wheeled Motorcycle
  1. #201
    Sep 2022
    Final Install of Driver's Cockpit outer panels and odds-n-ends
    Hey Y'All,
    I wanted to install all of the rest of the cockpit panels (except the large rear panel), but ran into typical planning issues: I am running out of my favorite multi-grip rivets and I haven't ordered my soundproofing / thermal insulation mats yet...
    Here's how far I got: Driver's outer panels. Anyway, here's some pictures driver's cockpit outer panels1.jpg driver's cockpit outer panels2.jpg driver's cockpit outer panels3.jpg
    Not wanting to just leave it at that, I decided to finish the installation of my charcoal canister and breathers. I like how it turned out
    view looking toward front of vehicle final breather install1.jpg, view from above ... looking down final breather install2.jpg
    Next, I installed my rear brake hardline and brackets to the main frame tubes. I used some black gasket maker to keep the corrosion at bay underneath the brackets (and to hold into place if I need to adjust the lines a little). I had a picture, but the image quality was bad...
    Next, I wanted to install the rest of the Driver's footbox panels, then realized that some builder's wished they had added the Cool-Mat before inastalling the inner panels. I checked and decided to heed the advice. Not much room to get insulating mats in there driver's inner footbox panel needs insulation before being installed.jpg so I'll pre-fit the insulation before final installing that panel ... which means I'll be waiting on the next Summit delivery this week
    Until next time, Happy Building!
    Craig C
  2. #202
    Sep 2022
    Final Install of Passenger Cockpit outer panels and odds-n-ends
    Hey Y'All,
    Not too much progress this past weekend due to running other errands and taking care of Fall chores, but I did manage to "final" install the Passenger-side outer cockpit panels. While I was at it, I "semi-final" installed the fuel hardlines (I still need to install the decorative anti-scuff shim between the fuel lines and the Passenger-side floor panel).
    Here's the pictures: passenger cockpit outer panels1.jpg semi-final install of fuel hardlines.jpg passenger cockpit outer panels2.jpg
    I also painted 250 of my favorite-style rivets rattle-can chassis-black since Summit only has bare metal choices left No pictures 'cause that's kinda boring, but I just poked holes in some spare cardboard in a matrix pattern and painted top and bottom. Some of you may be thinking that this was a waste of time...perhaps, but one of my goals is to have Angelina look just as dazzling without her pretty red dress on
    Next time, I think I'll try some wire harness customization...
    Happy Building!
    Craig C
  3. #203
    Jul 2021
    Tonganoxie, KS
    While those rivets look nice, I can't imagine rationalizing painting something that will be totally covered by, say, carpet. But, if it makes you feel better about your project, I suppose it's worth it.
    Build Thread Here Partners: Summit Racing, LMR, Breeze, Forte's Parts, Speedhut, Amazon
  4. #204
    Sep 2022
    Thanks for following my build
    It is certainly proceeding slower than planned due to my OCD about trivial details
    Sometimes getting focused on very small things actually helps me to see the big picture -- as crazy as that sounds!
    Craig C
  5. #205
    May 2023
    I do like the rivets. Hidden or not. I'm thinking a dark grey metallic with some black rivets for the visible panels will look nice. Thanks for sharing.
  6. Thanks cc2Arider thanked for this post
  7. #206
    Kinda' like my buddy Bart who mirror finish polished every single interior and trunk panel then covered them with carpet! I think mostly it gave him something to do while he was in the garage drinking beer
  8. Likes cc2Arider liked this post
  9. #207
    Jul 2021
    Tonganoxie, KS
    Yep, very much the same. Although I did powdercoat every aluminum panel on my car...only to cover most of it in carpet.
  10. #208
    Sep 2022
    More trunk area prep
    Hey Y'All,
    I hope you had a nice Thanksgiving
    I spent part of my time getting the trunk area prepped for the final panel install...
    First, I double-checked that my harness with new split loom from WireCare would still fit where the drop trunk goes. I'm glad I checked! the Heavy-Duty split loom that I wanted to use added just a little bit more overall thickness than I had originally planned for. No worries, I just drilled for a new location for that wire clamp and now I have an extra screw location (if I ever needed it) Here's the result rear harness adjusted for drop-trunk clearance.jpg
    Next, I made a mini-harness for the taillight converter in case I ever decide (or can't get parts for the standard rectangular taillights) and have to resort to the double bullet-style. My intention was to run all the standard wires in the rear harness (even if they don't get used now) and have the option for the converter "delete". I used "flat" split loom and this was my 1st attempt at making WeatherPack connectors...taillight converter mini-harness.jpg and here it is installed along the normal loom with zip-ties taillight converter mini-harness installed.jpg
    Next, I finally decided to "mount" the parking brake cables "somewhere", and decided on magnetic mounts from MagDaddy. I affixed to the top of the differential case. I'm not sure if the installation will help to isolate the steel shavings anymore that the typical drain plug, but I figured it couldn't hurt...mag-daddy parking brake clamps on diff.jpg
    I liked how my 1st harness "redesign" came out. I used cloth harness tape to isolate each breakout and then for those critical areas, I also wrapped with self-sticking silicone tape. I ended up relocating the license-plate light wiring a good 10" from stock and created a break-out connector for the previously-mentioned taillight converter. I made a couple of mistakes and had to splice a mistakenly-cut wire and decided to double-up some wires, too, just as was done originally in some of the connectors. Here's a final look rear harness final install in perimeter of trunk.jpg
    Until next post, Happy Building!
    Craig C
  11. #209
    Sep 2022
    More odds-n-ends
    Hey Y'All,
    More catching up was done to get my trunk and driver's side inside footbox panels ready...
    First up: I decided to re-do my front brake hardline to have a better appearance and because I just wasn't sure if the prior attempt had issues with the AN flare...
    redone front brake hardline1.jpg and a side view redone front brake hardline2.jpg
    Happy with that result, I pre-assembled my drop-trunk panels: final pre-assy of drop trunk panels.jpg here's a close-up of properly formed multi-grip rivets. I think the key is to use a #30 drill bit instead of a simple 1/8". It allows the rivet to deform properly like a stack properly deformed multi-grip rivets inside the drop trunk.jpg
    Craig C
  12. #210
    Sep 2022
    Finally catching back up to pg. 167 of the Build Manual
    Hey Y'All,
    I finally got the details done to "final" install the Driver's side front footbox panel. It meant I needed to pre-fit some thermal padding and confirm the rear brake hardlines were properly fastened (snugged up w/anti-seize on the junction threads and with threadlocker for the mounting pads).
    Here's pre-assembly of the top and bottom inner footbox panels final install of driver's inner footbox panels.jpg
    Then pre-fitment of the thermal pad, including punched rivet hole relief, pre-bent and pre-indented for no interference with the standard AccPed bracket pre-relieved driver's inner footbox panel thermal pad.jpg then attached with the self-adhesive backing first thermal pad installed.jpg
    Here's the result final install of driver's inner footbox panel assy.jpg and "road gravel" view of rear brake hardline bulkhead connection rear brake hardline bulkhead detail.jpg
    I'm happy with the results
    Craig C
  13. Likes F500guy liked this post
  14. #211
    Senior Member danmas's Avatar
    Jan 2019
    Mead Colorado
    Really nice looking work.
    Current BOM
  15. Thanks cc2Arider thanked for this post
  16. #212
    Sep 2022
    Thanks Dan!
    I appreciate the feedback
  17. #213
    Sep 2022
    Upper (forward) trunk floor panel installed
    Hey Y'All,
    I managed to tighten my fuel lines at the junction of the flex lines running to/from the tank and filter to the hardlines running up the Passenger side, and then loctited the hardline mounting blocks to the frame for the final install under the car. This meant that I was (for the most part) finished with the details under the trunk area (until I get the tank mounted...
    This meant that I could "button up" the forward trunk floor panel finally
    Here's some pictures: Top side upper trunk panel installed.jpg and under side Driver's side under trunk view1.jpg Passenger Side under trunk view1.jpg Under trunk view without fuel tank.jpg
    Next time I'm under there, I'll be installing the drop trunk box, the lower rear trunk panel, and the fuel tank...
    Happy Building!
    Craig C
  18. #214
    Sep 2022
    The Best-laid plans...
    Hey Y'All,
    In my zeal to catch-up to get the cockpit panels installed, I realized that I skipped a step ...
    I wanted to add some in-tunnel thermal pads after all. I wish I made up my mind before I installed those panels
    Oh well...in order to properly apply the stick-on pads, I realized that I need to install that very small Driver's side access panel. I measured the distance to the drivetrain that has not been mounted yet, and I didn't see a reason to keep that access panel for any maintenance, so I decided to rivet and bond in-place. I used "normal head" 1/8" rivets since the proportion seems agreeable. Here's a picture: Driver's side tunnel small access panel.jpg
    Then I could carefully measure via paper templates how I wanted the thermal stick-on pad to be laid-out. It was still a little bit of a struggle to position and press on (kinda burnish) the pad into place...then just as challenging was to measure, locate, and place the seam tape. This was the "easy" side. I'll try the Passenger side tomorrow. Anyway, here's a picture of the result: Driver's Side tunnel heat shield with seam tape.jpg
    I didn't actually use a rubber roller for this install. Instead, I actually used some plastic trim removal tools. I used the one that's kinda shaped like a putty knife. I think it worked pretty well
    Happy Building!
    Craig C
  19. #215
    Sep 2022
    Finishing up the Trans tunnel thermal pads/mats
    Hey Y'All,
    I got the Passenger side in-tunnel thermal pad installed and finished up the edges with the seam tape. Here's some pictures of the progress: Passenger Side tunnel heat shield with seam tape.jpg and here's a powertrain perspective of the completed job Tunnel heat shield with seam tape.jpg
    Next post: finally catching up to p.169 of the Build Manual...
    Craig C
  20. #216
    Sep 2022
    Catching up to p.169 of the Build Manual
    Hey Y'All,
    I finally got caught up to p.169 of the Build Manual. I decided to use "normal" head 1/8" rivets along the top edge of the trans tunnel so that I'd have adequate room for the trans top panel with all the dimensional stack-up of pads/carpet (or upholstery), etc. The remaining rivets were all "large" head. Here's the pictures: Cockpit inner rear panels1.jpg Cockpit inner rear panels2.jpg Cockpit inner rear panels3.jpg
    Craig C
  21. #217
    Sep 2022
    Trunk Panel final installation
    Hey Y'All,
    After getting the trans tunnel panels thermally insulated, my next task was to install the remaining trunk panels for the final time
    The order that I chose worked for me, but to be honest, I probably should've installed the side panels later in the sequence. Anyway, here's the inner side panels Passenger side inner rear trunk panel.jpg Driver's side inner rear trunk panel.jpg
    Then, I checked the rear frame rails for straightness and decided to add some shims to the rear trunk frame tubes before I installed the rear trunk panel (the reasoning will be more clear in the upcoming pictures) adding shims for rear trunk panel and bracket.jpg then installed the rear trunk panel and my "extension" bracket installed rear trunk panel and bracket.jpg
    Here's why I spent time with the shims: ("extension" bracket is nice and straight!) detail of rear trunk panel bracket straightness.jpg
    Next post: final installation of the fuel tank
    Craig C
  22. #218
    Sep 2022
    Catching up to p. 193 of the Build Manual (installing the fuel tank)
    Hey Y'All,
    I finally installed the fuel tank today, and it feels like real progress has been made this past week
    Minor setbacks or concerns just present problems that get to be solved -- one by one
    I'm happy that I spent some thought up-front about the rear harness and fuel line routing, because I suspected that I'd need to connect things before the tank was in the final position. My solution was to simply have more length than needed and simply loop the wires/lines so that they could be connected first, then raise the tank without messing up any geometry or layout. Worked out well...
    Here's some detail pictures that might help others (sending unit harness loop w/MagDaddy zip-tie mount) detail of fuel sending unit harness underneath the installed trunk panels.jpg
    (fuel pump harness and flex lines w/MagDaddy zip-tie mounts) detail of fuel pump harness underneath trunk panels.jpg detail of fuel pump harness underneath trunk panels2.jpg detail of fuel lines underneath trunk panels.jpg
    Next project: finish plumbing the brake system and bleed it...
    Until next time -- Happy Building!
    Craig C
  23. Likes F500guy liked this post
