Results 1 to 5 of 5
Thread: Russ Thompson turn signal dissasembly
    Oct 2021
    I'm finishing wiring and just realised that the right turn signal on the Russ Thompson turn signal has poor connection and does not work. If i wiggle the stalk which does have quite a lot of play i can get it to work, so i think there is an issue with the contacts inside. The left signal works perfectly fine.
    Anyone has taken one apart and can share some tips on what to do or more importantly what not to do? I have no idea what i'm doing, so any help is greatly appreciated.
    Thanks.
    there is a light duty snap ring that holds the whole thing together. Just carefully remove then lift the 2 pieces apart. The issue should be very visible. Its a very simple switch.
    i.e.427's Avatar
    Nov 2016
    "The i.e." SoCal
    I cover the disassembly and the reassembly in this video.
  4. Likes danmas liked this post
    Oct 2021
    Thank you for the replies - I will try to see what is up with it.
    Oct 2021
    Just a follow up:
    It is a very simple design and easy to disassemble as per both comments above. I took it apart, cleaned the contacts which were a bit dirty and now it works perfectly fine.
