Results 1 to 14 of 14
Thread: Fuel-pump
    Sep 2022
    Ogden utah
    Cool Fuel-pump
    Where to mount fuel pump mk4 3 link suspension. Any suggestions as to what works best. Here is the pump I'm considering if that helps. Any recommendations are appreciated thanks.
    https://www.amazon.com/Gautory-Unive...p?ie=UTF8&th=1
    Some use an external pump. But an in-tank fuel pump is more common and has advantages aside from not having to find a place to mount. An in-tank pump is quieter and runs cooler. Something to consider.
    Oct 2020
    Albany, NY
    I ran an external pump on my first car and mounted it under the passenger side seat pan. It drove me absolutely nuts. Under 40mph all I could hear was it loudly droning. After less than 2 months on the road I bit the bullet and retrofitted an in tank pump. Game changer.
    Build Thread #1 https://thefactoryfiveforum.com/show...been-delivered
    Build 2 MK4 #11061- Delivered 08/24/24
    Build Thread #2 https://thefactoryfiveforum.com/show...006#post562006
    Dec 2021
    Flower Mound TX
    Quote Originally Posted by Cobraman View Post
    In the fuel tank.
    Oct 2019
    Erin, Ontario CANADA
    I'd be going for something with better "broke-down-on-the-side-of-the-road-in-the-middle-of-nowhere" availability like a Walbro GSL392BX.
    Earl
    Sep 2022
    Ogden utah
    Could you give me some details as how you accomplished this. Because now the hanger that comes with the kit won't take a pump and the pumps on summit racing site that includes hanger don't have enough lph to supply my engine. They are only rated at 176 lph my engine needs 300 lph that excludes a 33% cushion
    Sep 2022
    Ogden utah
    Senior Member danmas's Avatar
    Jan 2019
    Mead Colorado
    What engine do you have?
    I have a 351w bored and stroked to a 427 @ ~550hp and I have this:
    https://breezeautomotive.com/shop/25...th-3-8-outlet/
    Mk4 complete kit arrived 10 May 23
    Current BOM
    Jun 2023
    Texas Hill Country
    Cobraman, many of us use the Pro-m hanger and a Walbro 255 or 340 pump. It has 3/8 (6AN) fittings for output(Feed) and return. Check their videos out.
    https://www.promracing.com/high-flow...-mustangs.html
    BUDFIVE
    Complete kit order 8/28/2023
    347 Ford Dyno 10/12/2023
    Kit Delivery 11/28/2023
    First Start 7/4/2024
    Go Cart 8/31/2024
    Sep 2022
    Ogden utah
    I'm running a Windsor 408 stroker 500hp
    Oct 2020
    Albany, NY
    I used a unit from quantum fuel systems. It’s a little more bang for your buck than the pro M unit. I went with a bigger LPM so I have the option to run a supercharger down the road. Anyhow fits the same. You will have to slightly modify your tank opening however. Not a big deal, lots of folks have done it. I did it the first time with fuel in the tank with snippers and needle nose.
    https://www.ebay.com/itm/16184180451...mis&media=COPY
    May 2023
    A 255lph Walbro is more than enough. They are a dime a dozen. Buy a hanger kit that includes the 255 and call it a day.
    Quote Originally Posted by BUDFIVE View Post
    I've used this exact setup on four builds. A SBF, two Coyotes, and an LS. Bullet proof. I've seen a couple of builds use this pump from Aeromotive. Seems like a decent option. I've used their regulators and have always been impressed with their quality. https://aeromotiveinc.com/products/8...YGiYf0-3fE019Z
    Sep 2022
    Ogden utah
    Thanks I'll look at it
