Anyone Have Spare Carpet?
Does anyone have any MkIV carpet they're not using? I've decided to ditch the standard park brake setup in favor of the Wilwood electric park brake setup. I've already installed my standard park brake and carpet, so I'll need to patch the hole in the aluminum, and then carpet over the patch. Even better, if anyone has the large piece of carpet that covers both sides and top of the trans tunnel, I could simply recarpet the passenger side of the tunnel.
Thanks!
Greg
Build Thread Here Partners: Summit Racing, LMR, Breeze, Forte's Parts, Speedhut, Amazon
MkIV Complete Kit Ordered 4/18/23, Delivered 7/11/23, Boss 427W, Edelbrock Pro Flo 4, TKX (.68 5th), IRS, Wilwood Brakes, 18" Halibrands, Toyo R888R Tires, Custom Speedhut Gauges
Nevermind! I found a piece I didn't use...the top of the trans tunnel. Duh.
