Results 1 to 5 of 5
Thread: Grease fitting hitting steering rack
    Sep 2022
    Huntington, IN
    Grease fitting hitting steering rack, lower control arm rear. Anyone else have this issue?
    May 2018
    Pinckney, MI
    I remember working to find an orientation for the fitting as well. I dont think the OOTB location worked. I get to discover again with the 35 Truck...
    - Peterh226
    35 Hot Rod Truck (Ext) Delivered 11/21/24
    33 Hot Rod Gen 2 #1134 ~1400 miles
    54 Pontiac Star Chief
    05 F-150
  3. Likes Just 1 More liked this post
    Bourne-Cape Cod, MA
    Yes, drill a new hole in the steel collar. Put a grease fitting in the new hole. Plug the old one.
    FFinisher/AKA RE63
    Kingsland, TX
    Mine are near the rack at full droop, but when you put the car on the ground the zerks rotate down away from the rack.
    Sep 2022
    Huntington, IN
    It's all fixed now, plugged the old one and put a new one in a different location.
